weird pinging issues...need help.
Old Jan 10, 2009 | 02:39 PM
  #201
trucklover's Avatar
trucklover
Originally Posted by aim4squirrels
no vac leak, I have 21inches at idle and between 20 and 24 while driving. Haven't checked WOT; too scared to stare at the gauge taped to the window going full out.
you may have already metioned this but did you ever do the vacuum test where you connect the vacuum guage to the breather line and plug the PVC port and pvc valve (before you did the plenum repair this last time)? Or did you only check the amount of vacuum that was in the intake?
I am just wondering how accurate the vacuum test is that is described in the TSB for checking the plenums
Old Jan 10, 2009 | 03:23 PM
  #202
aim4squirrels's Avatar
aim4squirrels
Originally Posted by Rex-TheDOGG
How black were they? If the insulator, electrodes, and cavity were all black, then you aren't running lean, obviously.
Cavities were black, the resistor was still white (a few had a small black ring forming right at the bend down into the cavity, and almost all of the electrodes had a white powder film on them.
Old Jan 10, 2009 | 03:28 PM
  #203
aim4squirrels
If the plenum is leaking at the gasket area, the gases that would normally escape thru the PCV would never build up as they would be sucked into the engine vacuum thru the plenum leak. The engine vac should be strong enough (on a stock cam at idle, anyway) to cause a vacuum thru the PCV as well. Now, the pintle may stop the reverse flow of air, but if you removed it you should most definitely have suction ther if the plenum is leaking.
Old Jan 10, 2009 | 07:46 PM
  #204
trucklover's Avatar
trucklover
Makes sense. My truck has started a light tick when you are accelerating right around the 2500 rpm mark. Even if you have it in neutral and rev the engine you can hear a ticking sound around this mark. I am not exactly sure if it is a spark knock or coming from something else. I have the hughes kit installed in the plenum and it passed the vacuum test, and there is only a light amount of oil residue in the bottom of the intake (no puddles). The area where the plenum pan meets the intake looks a little wet (in the gasket area) but there are no puddles in the bottom. I have been following your ordeal hoping you may discover something! My truck has good power, but the gas mileage has got a little worse lately along with the tick. I thought for sure the plenum was acting up, but now I am not sure. I may tear it down when the weather gets a little warmer and double check everything. I am running the Superchips but I reset the truck to stock and am still hearing the same tick (and this is with running 93 octane). Mine could possible be an exhaust leak starting, I just don't know! Good luck with finding the solution to your problem.
Old Jan 10, 2009 | 08:42 PM
  #205
aim4squirrels
I'll bet you have lifter tick, caused by a sticky lifter.
Old Jan 10, 2009 | 11:54 PM
  #206
lv360ram's Avatar
lv360ram
The last 4 Dodge magnum engine trucks I've had all had the "magnum tick". A friend had a 96 Durango with the "tick".
The tick comes and goes. When it is happening it is really noticable while waiting in drive thru for fast food because the tick bounces off the wall. I believe the tick I'm talking about is valve tick from a sticky lifter since it doesn't happen all the time.
Old Jan 11, 2009 | 06:48 AM
  #207
trucklover's Avatar
trucklover
Wouldn't you hear a sticky lifter at idle? You can only hear this when the engine is turning around 2500 rpm.
Old Jan 11, 2009 | 09:09 AM
  #208
aim4squirrels
Only at 2500? And is it reproduceable?
That's not lifter tick, sorry for mis-diagonsing. Start a new thread so the answer doesn't get lost in this one.
Old Jan 11, 2009 | 09:18 AM
  #209
trucklover's Avatar
trucklover
Will do. THanks!!
Old Jan 11, 2009 | 10:18 AM
  #210
aim4squirrels
2 more misfires yesterday, wonder if I've been dealing with a head crack that's been getting progressively worse.
