Noises/Vibrations from front end
Old Feb 8, 2005 | 05:01 PM
Ramtooler's Avatar
Ramtooler
Default Noises/Vibrations from front end
Hey guys and girls. I have a 96 Ram 1500 4x4 with about 88,000 miles on it. When im drivng down the road there is a loud thud/vibration coming from right up under where the front passengers feet are. If your a passenger you can really feel it bad. Now i know that the top control arm bolts up in that area and was wondering if it might be bad bushings on them or if it might be worn out suspension parts. It almost feels like the front end isnt attached to that side, but it is. Any help is greatly appreciated. Thanks, Kyle
Old Feb 8, 2005 | 05:07 PM
wkeiter's Avatar
wkeiter
Default RE: Noises/Vibrations from front end
I have the same problem with my 01 Ram and I'm being told its probably the crappy Track Bar running from the axel on the passenger side to the crossmember on the driver's side. Haven't changed it out yet, still debating on going with a DT Track bar or a Thuren Track bar. The DT just bolts on after some drilling and the Thuren requires welding, I would like to go with the Thuren but need to find a shop to weld the bracket on. I can feel the same thing in the floorboard on the passenger side, hope this fixes the problem!
