Shock Size?
Shock Size?
I plan to put a 1.5" coil spacer in the front and replace my shocks (since they're in need or replacement anyway). I'm looking at Rancho RS5000's... and going with the 2-3" lift version for the front. However, with the rear shock replacement, should I go with 0" lift since it hasn't been lifted... or should I go with the 2-3" lift size?
The reason I ask is because I read a thread where someone said that because there is the 3" stock block in the back- that it is considered a 3" lift. I don't see how that is true- since it came from the factory with the block and is considered 'stock height'. So I want to make sure I get the correct size for the rear- I'm assuming that it would be the 0" lift (stock height).
Thanks for the help.
