High and lows on at same time?
Old Nov 9, 2008 | 06:25 AM
TIMIDONE's Avatar
TIMIDONE
Wink High and lows on at same time?
So I've seen post and diy to have both high and low on at same time...if you have the sport housing for lights...is there anyway to do it if you don't? I mean I have a single bulbs. I noticed when I switch to high to low both lights come on until I click all the way down.
I would love a way to do both without having to get the sports housing for lights...any ideas?
Old Nov 9, 2008 | 09:01 AM
charlie1935's Avatar
charlie1935
That is hard on headlight switches and generates more heat in the light also.
Old Nov 9, 2008 | 09:02 AM
aim4squirrels's Avatar
aim4squirrels
I would think that would get darn hot quickly and everybody on the road would hate you.
Old Nov 9, 2008 | 01:34 PM
TIMIDONE's Avatar
TIMIDONE
Everyone on the road I wouldn't care...but I wouldn't run them unless I was off road.
Yea I thought the switch would get hot...just was hoping! Ok who has a sport light housing for sale to me?!!
Old Nov 9, 2008 | 01:43 PM
charlie1935
If you go with the 99/01 sport lights Daniel Stern . com has the wiring harness you'll need complete with relays that take the load off the switch.
Old Nov 9, 2008 | 09:00 PM
jasonw's Avatar
jasonw
Site Moderator
Or you can wire it yourself. DIY #41 I believe.
When I accidentally had my headlights wired incorrectly (crossed the low beam and ground wires), I was running my bulbs with highs and lows on at the same time, and didn't realize it. I thought my lows were really great, and that my aftermarket housings just sucked for high beams. Burned through a bulb about every 6 months to a year. I usually attributed it to mishandling when I was messing with something with them, but looking back on it, I'm not sure.
Old Nov 9, 2008 | 09:44 PM
dhvaughan's Avatar
dhvaughan
the easiest way to do this is with a "brite box". i've got one, had it for two years, and love it. installs in 5 min. no problems so far.
here's one place to get it, there are others.
watch out for the proper model ( sport vs non-sport, and fogs/no fogs)
http://www.performanceproducts4truck...spx?pid=111652
Old Nov 9, 2008 | 10:47 PM
Viper37's Avatar
Viper37
Good god that is a ridiculous price for a relay.
Just get a light relay, some wire, and some headlight connectors. You can do it cleanly for under $20.
Old Nov 10, 2008 | 12:05 AM
TIMIDONE's Avatar
TIMIDONE
Wow $95...no thanks but thank you. So viper...I can do it under $20...any direction you can give?
Old Nov 10, 2008 | 12:15 AM
Viper37's Avatar
Viper37
Yeah get a standard automotive relay. Connect the 12v in to your battery, 12v out to your positive pins on your lights. (using splitter cables) Then connect the switching means to your factory harness.
If you rob the sockets off old bulbs, or you can buy them online.
If you get new sockets, it will probably cost around $30 for the whole setup. If you decided to just tap into your factory wiring and use some diodes, the whole mess will cost prolly around $10.
