Pulling air directly from engine bay
Old Nov 12, 2008 | 08:50 PM
  #41
Viper37's Avatar
Viper37
I honestly don't have any desire to talk to this bigot privately. There is no excuse for racism.
Old Nov 12, 2008 | 09:16 PM
  #42
TXcharger07's Avatar
TXcharger07
Originally Posted by 360dodgeram360
i love the hemi! however i see them more as race motors. in my opinion, the magnum 360 is the best truck motor. it is super reliable and has a hell of a lot of torque. not to mention it is easy to work on and doesn't have all the fly by wire and complicated systems.
very, very true. and you can probably make a 360 just as fast with some good work. and there's no replacement for displacement :P
Old Nov 12, 2008 | 09:56 PM
  #43
vmann's Avatar
vmann
ive heard that the 360's are very under tuned from the manufacturer and do not run at full potential. What do i need to unleash my hidden power?
Old Nov 12, 2008 | 10:14 PM
  #44
TXcharger07
hahaha bore and stroke to a 408in! thats the hidden power
Old Nov 13, 2008 | 06:01 AM
  #45
trucklover's Avatar
trucklover
Superchips works well and you can usually pick up a used one for around $200-250. Just make sure it is unlocked. THe air intakes help, modified throttle bodies (Fastman or you can even use a Dremel tool and port and polish your own), and a good tune-up are just a few places to start. What I like about these engines is it doesn't cost an arm and a leg to modify them.
Here is link for modifying the throttle body: http://dodgetruckworld.tenmagazines....erformance_mod
Old Nov 13, 2008 | 10:07 AM
  #46
TXcharger07
look at modding other motors... then look at the dodge's lol its a little bit more expensive.
Old Nov 13, 2008 | 10:13 AM
  #47
Silver_Dodge's Avatar
Silver_Dodge
That's the difference between a MAF system and a speed density system.
Old Nov 13, 2008 | 11:05 AM
  #48
trucklover's Avatar
trucklover
I was looking for a Cold Air Intake for a friend of mine's Furd F-150 (2006). The cheapest I could find for his was around $300.00 and from what I read, the Furd's engines do not like the "home-made" cold air intakes (it may throw a code). But, on our Dodges we can put a $25.00 14" round air cleaner and have the same performance as an expensive CAI. All the expense the TB modification I did was the cost of the Dremel bits. The programmer cost around $200-250, but according to Superchips you gain close to 50 horsepower (at least thats what they claim!), not a bad return for the money. This is why I said you can modify these engines to get the extra power that these engines are capable of without spending a lot of money. NOw if you get into cams and etc that may be a different story.
Old Nov 13, 2008 | 01:53 PM
  #49
vmann's Avatar
vmann
how safe is modifing the TB? looks easy but will it affect inspection etc?
Old Nov 13, 2008 | 03:45 PM
  #50
trucklover's Avatar
trucklover
I really don't know about the inspections. Where I live they don't check any of that.
It is a pretty easy mod.
