Dual air intake
Old Feb 10, 2005 | 03:03 AM
Silver_Dodge's Avatar
Silver_Dodge
Default Dual air intake
Anyone had a chance to try one of these dual air intakes? Just wondering how it compares to the usual single side air intake.
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
My Airaid intake seems much longer then this to get the filter farther away from the exaust manifold heat. When I was installing mine, I thought a dual snorkel setup would look cool though.
Old Feb 10, 2005 | 01:58 PM
steve05ram360's Avatar
steve05ram360
Default RE: Dual air intake
that has trouble written all over it!!!
your putting your air filters right above the exaust.. dumb, you'd be sucking in hot air at every stop light, causing heat soak on the intire intake system...stay away from it...
One suggestion would be to move the air filters to the front of the truck and insulate the tubing going back to the air hat... that'd work!
There is another solution out there for dual air inlets... I'll go look for it.
Old Feb 10, 2005 | 01:59 PM
steve05ram360
here's the link...
Ram Air Box
Old Feb 10, 2005 | 06:20 PM
RamRod360's Avatar
RamRod360
which one would I order though?
Old Feb 10, 2005 | 07:44 PM
steve05ram360
with the ram air box, you'd have to make sure it'll fit under the hood and order the right depth box... so you'll need to get out the tape measure. I saw a Ram with this on it a while back and it looked awesome, it had the magnum top to it instead of the one that comes with the box... 2 flex tubes running to the front of the motor, not insulated however... that's something I'd add to prevent heat soak.
Old Feb 10, 2005 | 11:24 PM
Silver_Dodge
I wasn't implying that I wanted one. I am happy with my Airraid. I was just curious if anyone out there had tried one.
I do like the Ram Air Box though. Might look into it.
