Cam bolt on lower LCA
Old Nov 16, 2008 | 03:13 PM
slowram's Avatar
slowram
Default Cam bolt on lower LCA
Hey guys how many of you have messed with the cam bolt on your lower control arms on when you put your lift kit on. Im thinking of turing mine so i can push the front axle out a lil more. Because i still rub a lil bit when im driveing and turn my wheel But if im sitting still and turn my wheel i dont rub at all. It has 5 inch of lift with 315/75/16 i should be clearing them i dont know whats wrong
Old Nov 16, 2008 | 10:59 PM
rabbler's Avatar
rabbler
Are you rubbing on the fender or the control arm?
Old Nov 17, 2008 | 04:49 PM
slowram's Avatar
slowram
On the fender
Old Nov 17, 2008 | 05:17 PM
Silver_Dodge's Avatar
Silver_Dodge
I think you need longer lower control arms to accomplish that.
Old Nov 17, 2008 | 05:24 PM
slowram's Avatar
slowram
Yea thats what i thought wasnt sure do all 5 inch kits come with longer control arms. Im just tired of it rubbing and DO NOT want to do a body lift any ideas
Old Nov 17, 2008 | 05:28 PM
Silver_Dodge
Ya, most kits over 3" have new arms. Your still running the stock arms?
Top Gunz makes a pretty inexpensive set of adjustable tubular arms. They are not heim joint ends though, just poly bushing ends like the stock arms. I went with Skyjacker tubular arms on mine. No heims on mine either, but you can get them with either single or double. Just depends on how hard you wheel you ride if you think you need that kind of flex.
Old Nov 17, 2008 | 05:40 PM
slowram's Avatar
slowram
Ok thanks how much are they and where did you get the sky jacker ones
Old Nov 17, 2008 | 05:49 PM
slowram's Avatar
slowram
would this also be why my ride is rough
Old Nov 17, 2008 | 05:57 PM
Silver_Dodge
You can get them from Summit, Rocky Mountain Suspension, or lots of other on-line places.
