Cooling Problem Diagnostics
Old Nov 21, 2008 | 12:14 PM
MrMiracle's Avatar
MrMiracle
Default Cooling Problem Diagnostics
This problem began this morning. As I was driving into work, I noticed that I wasn't getting any heat at all from my vents, even though the engine was warmed up. As I arrived at work, I noticed that the engine was running very hot on the temp gauge.
The ride to work is short, so there wasn't that much risk. I figured maybe there was some ice in the radiator or that the coolant level was low. I topped off the coolant with some 50/50 I keep handy and checked the radiator. Sure enough, there was a bit of coolant-ice on the driver's side of it.
I drove home and encountered the exact same problem. Engine getting hot, no heat from the vents.
Arriving home, I checked the radiator again. There was still ice on it, and there was a small drip coming from where the ice had formed. I concluded that no warm fluid was running to the radiator (otherwise it would have melted).
Based on these events, my first and worst conclusion is that it is the water pump. I'm not getting any flow to the radiator or the heating core, both of which are provided by the pump. The radiator will need to be replaced eventually anyway (its leaking after all), but the pump is going to keep the truck from being usable for the immediate future.
Does this seem like the correct conclusion?
Old Nov 21, 2008 | 12:27 PM
busaguy05's Avatar
busaguy05
Your mixture should never freeze. If it does freeze it's a sign that you have added to much water to the system. 50/50 is not always the proper mixture for all climates.
Old Nov 21, 2008 | 12:52 PM
MrMiracle's Avatar
MrMiracle
That's true about the mixture. I'm in the process of moving to a colder climate, so these things will start coming up more often. I'll try running the engine once the day gets warmer, but that hasn't quite answered the flow problem.
Old Nov 21, 2008 | 02:26 PM
HankL's Avatar
HankL
the stock Magnum engine thermostat is a
Robertshaw/Seib made 'standard grade'
195 degree unit that has a steel upper section and brass under-arms
sadly,
the brass under-arms have a bad tendency to crack
which leaves the thermostat not able to operate right
Old Nov 21, 2008 | 07:19 PM
zman17's Avatar
zman17
Retired Moderator - RIP
sadly,
Ok , so what is the best one to get? Or is it just pot luck to get a good one?
Old Nov 21, 2008 | 07:44 PM
aim4squirrels's Avatar
aim4squirrels
I like the Stant superstat.
Old Nov 21, 2008 | 08:49 PM
dhvaughan's Avatar
dhvaughan
if you compare the $10 stant with the $5 cheapo you'll see that the stant has more material. since it takes an hour or more to change it and you don't want to be stranded on the side of the road, get the best one.
Old Nov 21, 2008 | 10:42 PM
guitarking135's Avatar
guitarking135
I live in indiana and I run a 60 40 or maybe even as much as 70 30 because it can get pretty cold around here. I would suggest running a little more coolant and less water.
Old Nov 22, 2008 | 06:06 AM
zman17's Avatar
zman17
Stant is what I have used for years in all my vehicles . Have had a couple bad ones. And almost every time in the past I installed a cheapo that someone bought themselves, I had to do it over for them. Now I make them get a Stant or I don't do the work for them.
Old Nov 22, 2008 | 01:31 PM
wingnut71's Avatar
wingnut71
quick question not sure if this is the right place for it but here it goes .. why does everyone say they have a 180 degree thermostat and what benefits are there if any by changing from a 195 to a 180 stat. thanks
