Standing water in cab
Old Nov 23, 2008 | 05:26 AM
Ritzieann's Avatar
Ritzieann
Default Standing water in cab
Hey everybody! I'm new here, been waiting 2 days for my account to allow me to finally make posts! I'll say this first, if I "sound like a girl" I'm really sorry. I feel like a retard when I talk about my truck because I truly know little about trucks. Though, please don't talk to me too much like a kid, because I do know my way around the basics. In fact, I'm on another forum and Just completed an entire engine swap in one of my Hondas. I just hit a wall kind of when it comes to my truck.
I've got a 95 Ram 1500. It's in good condition, nice paint, only 82,000 miles, new tranny at 52,000. I'm the 3rd owner, but just purchased it from my folks, who've had it since 20,000 miles. They've kept the truck in good condition, exelant really, even though it's always lived outside.
The problem is that after recent rain, the truck is taking on water into the cab. It had this issue a while back, last year or maybe it was the year before. My step dad had thought he fixed it. Apparently not.
The ONLY part of the truck that is wet is the carpet. And it's soaked. Like, if you push on the rug a little bit, then the water rises above the carpet pile
The stereo has been on the fritz and we assume it's due to the excess moisture. It mostly doesn't work but when it does it sometimes picks up another signal, and then freezes. I can even shut it off and the "other channel" keeps playing. I'll probably make a thread on that in a little while.
The truck lives at my folks place, because of my current living arrangements. 3 vehicles isn't exactly welcome at my apartments :P
This is a picture of where my truck is parked. (The Honda is my project car, the one I just swapped engines in). It's the only picture I have of where my truck is primarily parked. See the portion of garage that's actually finished? The truck is normally parked in front of that. Those are pine trees. They clog the gutters of the garage, but haven't appeared to fall all over the vehicles.
Anybody else with this problem?
Old Nov 23, 2008 | 05:45 AM
Laramie1997's Avatar
Laramie1997
Thats kinda different... Have you checked the rubber weather stripping between the door and the cab? make sure there isnt an antifreeze smell to the water either.
Are there holes in the roof???
Old Nov 23, 2008 | 06:02 AM
Ritzieann's Avatar
Ritzieann
hehehe. No.
The weather stripping looks fine. And, besides, the doors are never wet, or the dash. Not the seats either,it's always just the floor.
The windshield is in good shape, but I'm thinking it's original, I'll have to ask the folks for sure.
I HATE searching for leaks. Only leak I've had before is in my 86 (the one in the pic) it's got a small leak in the hatch, but at least it was easy to find and will be easy to deal with. Plus that one is tiny, and the truck- well, the carpet on BOTH sides just gets soaked.
Old Nov 23, 2008 | 07:01 AM
White Ram's Avatar
White Ram
This problem is well documented in this forum. Do a search.
I had this problem as well. For me, replacing the 3rd brake light gasket fixed it. When I took the light out, it was obvious why it leaked - gasket was not installed correctly in factory.
Old Nov 23, 2008 | 07:13 AM
plott hound's Avatar
plott hound
my '96 ram had the same problem.turns out the door pins were wore out,thus not allowing the door to seal on rubber properly.replaced door pins and bushings and the leak was gone.
Old Nov 23, 2008 | 08:36 AM
charlie1935's Avatar
charlie1935
Another common leak is around the high mount stop light on the back of the cab. Water can get to floor from there with nothing else getting wet.
Old Nov 23, 2008 | 11:16 AM
vmann's Avatar
vmann
possible ac drainage seeping into carpet? that was my problem for a while.
Old Nov 23, 2008 | 11:35 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Take a hose to it and look and see where it coming in.
Old Nov 23, 2008 | 03:35 PM
dodgeram07's Avatar
dodgeram07
i have a 95 and it took my forever to find my to leaks.. one was the gasket around the third brake light, the other was around the back window(see pic) it would leak down those hole.. the water would run all the way down to the floor boards... hope this helps
Old Nov 23, 2008 | 07:58 PM
BlueBeast2's Avatar
BlueBeast2
mines been doing this ever since I started ripping the engine apart. I'll have to look into all this stuff when I'm done the engine work
