Noise like water is stuck somewhere
Old Nov 28, 2008 | 11:56 AM
hjpark's Avatar
hjpark
Default Noise like water is stuck somewhere
I bought a 99 V8 Laramie SLT Dodge Ram about 6 months ago. Even though I like the truck a lot, I've had my share of problems. I've had the rear brake drums, lower ball joints, plenum gasket, serpentine belt, rear tires, and water pump replaced. Now she runs great. However, whenever I get it back from the shop I hear a noise similar to hearing upstairs plumbing while in the basement. It sounds like water is flowing around under the dash. It only happens when I accelerate or brake, but it doesn't seem to be related to the engine spinning. After a few weeks it went away last time, but now it's really annoying. Any ideas?
Old Nov 28, 2008 | 12:00 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the coolant level, you have air in the system. The noise you here is coming from the heater core, which is under the dash.
Old Nov 28, 2008 | 12:07 PM
talon6's Avatar
talon6
https://dodgeforum.com/forum/2nd-gen-ram-tech/181153-gurgling-noise-in-passenger-side.html
here you go.
