What is this and what does it do?
Definitly carefull when routing the wire for it back in... I did my tranny swap and pinched the wire between the bell housing and block. needless to say truck wouldnt start, the engine will rotate but wont fire, it sends a code and kicks on the ASD relay wich in turn kills the spark and Fuel systems. about a month later i did and engine swap on the truck, this time i was carefull on how i routed the wire... however not carefull enough. the wire harness was to tight and when the engine torqued it ripped the wire out..... I have now done about 4 CPS in totall... Again if you are replacing it dont buy a cheap one, ive seen them go time after time.
