Another lesson learned
Old Nov 29, 2008 | 12:04 AM
CSXfan's Avatar
CSXfan
Default Another lesson learned
Hi all, I just need to vent so feel free to ignore this.
I've been trying to fix my fog lights for a while now and today I finally got it done, but it cost me way more than it should have. I started out by buying two new bulbs -nothing. Then I tore the headlight switch out and opened it up (broke it in the process). Drove a 26 mile round trip to autozone for a new switch, turned out it wasn't even close to being the right part. After another 26 miles I had the correct switch, and when I plugged it in -nothing, crap...there goes 45 bucks. Finally started tracing the wiring and found a corroded splice. I spliced in a new 3 inch strip of wire and voila! The lamps now work perfectly. So a project that should have cost me 50 cents ended up costing me about $50. Nice....
FYI, if you're looking for a headlight switch for a 1999 ram with fog lights, autozone's website is incorrect. The one they are trying to sell for the '99 will only work on '97 and older 2nd gens. I think. They will try to tell you that it will work but there's no chance. I ended up buying a headlight switch intended for use in a 1999 durango w/ fog lights. It's the exact same thing that's in the ram.
Old Nov 29, 2008 | 05:39 AM
jasonw's Avatar
jasonw
Site Moderator
On the bright side, the stock headlight switches usually burn up eventually anyway. So you could look at this as preventative maintenance.
Old Nov 29, 2008 | 05:45 AM
talon6's Avatar
talon6
^^^^^on the bright side^^^^ lights,to funny jason.
Old Nov 29, 2008 | 09:06 AM
iwhitne's Avatar
iwhitne
LOL nice pun! hahaha
Old Nov 29, 2008 | 12:13 PM
dhvaughan's Avatar
dhvaughan
sounds like one of my repairs.
new ctm for $120, new multi-function sw for $42, 2-3 weeks of work and fret when the problem was a missing 50 cent fuse labeled power windows (or locks ?) and i don't even have power windows or locks.
look on "bright" side, you learned all about how your switch and wiring works. now you can answer all the fog light questions.
