Old Aug 6, 2015, 01:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Cooling System
Print Wikipost
how to replace my radiator on my 99 ram 1500
Old Nov 29, 2008 | 09:34 PM
patryk's Avatar
patryk
Default how to replace my radiator on my 99 ram 1500
i have ordered a new radiator but im not exactly sure on how to replace it and i cant afford to have it done at a shop
Old Nov 30, 2008 | 12:20 AM
BlueBeast2's Avatar
BlueBeast2
its pretty easy. At least it was easy yanking mine out. You drain the rad, remove hoses, remove tranny line which was the worst part. then you got the 2 top bolts to take out (pretty sure thats all there is) then pull that sucker out.
Now I forget if we removed the fan before yanking it out. I kinda think we did. So if you do you have to get a fan removal tool. Its just a bis *** wrench. You can rent it at autozone.
Old Nov 30, 2008 | 10:11 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Drain the radiator. Remove the upper and lower hoses. Now would be a good time to replace them unless they've been replaced within the last 80K miles or so. Remove the bolts that hold the shroud in place and then looses the mounts. It comes right out.
There's a Dodge Field Service Manual in the DIY thread. Download it and all the answers you seek will be found.
Good luck.
Old Nov 30, 2008 | 10:19 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You don't need to remove the fan, and the shroud will just slide over the fan out of the way enough to remove the radiator. Just be careful you don't slam the new radiator against the fan by accident when reinstalling. Or anything for that matter.
And actually, the most important part of the install is making sure the coolant is filled correctly .
Old Nov 30, 2008 | 10:58 PM
patryk's Avatar
patryk
k thanks alot!
