CB Install Image
Old 11-09-2009, 08:20 PM
mjackson92rs's Avatar
mjackson92rs
mjackson92rs is offline
Originally Posted by 95MaroonMonster
how well do your hood mounted antennas work
i used to have a single 4 foot on the left mirror and got a ton on interference (static) from the ignition system (damn gasoline engine, why cant you be a cummins)
I posted a picture of mine on here a few months back. My hood mount works great. I would recommend it. I'm sure people on here will whine about the ground plane not being "ideal" when mounted there, but it works great for me.
  #262
Old 11-09-2009, 08:45 PM
dodge15004x45.9's Avatar
dodge15004x45.9
dodge15004x45.9 is offline
My roof works good as well.
  #263
Old 11-09-2009, 09:25 PM
004x41500's Avatar
004x41500
004x41500 is offline
mine doesnt, but i now know why...
  #264
Old 11-10-2009, 04:58 AM
joekool4's Avatar
joekool4
joekool4 is offline
what pa speakers anyone know of a good brand or mounting spot?
  #265
Old 11-10-2009, 05:02 AM
BlueBeast2's Avatar
BlueBeast2
BlueBeast2 is offline
I got mine from a truck stop. I fotget the brand. It does the job. I have it mounted up before the battery so it aims out next to the rad. I'll get pics later if I remember
  #266
Old 11-10-2009, 08:41 AM
004x41500's Avatar
004x41500
i originally had the gold pa horn from a local truck stop it was made by diesel. but when i got a hole in the horn, i just cut the wire, and bought a 25w power horn from radio shack, and spliced the wires together, then used the plug to plug it into the back of my radio. the power horn was like 30 bucks, but it was worth it, its outlasted that little horn i had, and i have mine slid right behind my bumper on the drivers side, you can see it in some of my pics. it is weather resistant as well. iiits held up pretty good considering where its at.
  #267
Old 11-10-2009, 10:41 AM
bigtman07's Avatar
bigtman07
bigtman07 is offline
Here are a couple pics of my new antenna installation. I moved my 102" whip to the bumper and man did it make a difference in reception and talking.
  #268
Old 11-10-2009, 11:58 AM
TIMIDONE's Avatar
TIMIDONE
TIMIDONE is offline
without starting a debate but does whip antennas get better reception that regular ones (like firestick which I have). I am just curious cause I am in the mountains a lot...the whip would seem to get in the way because of all the forest I go through.
  #269
Old 11-10-2009, 12:43 PM
95MaroonMonster's Avatar
95MaroonMonster
95MaroonMonster is offline
years ago we used to have an old motorhome that had a bumper mount antenna that was like 10 foot tall, it looked pretty cool, the only problem with a bumper mount on my truck would be this winter when i install my gooseneck hitch
  #270
Old 11-10-2009, 01:52 PM
bigtman07's Avatar
bigtman07
I have used the fiberglass antennas like the fire stick and from what I have experienced and been told is that with fiberglass you won't get the same amount of vibration as you do with a steel whip. As in you won't be able to hear as well. Not the way of clarity but as in sensitivity. A steel whip is more sensitive than fiberglass making reception different. Now you don't have to have a huge whip like mine but you can go smaller. I will agree a long whip will get in the way. But I just put mine down military style when I'm going to a parking garage or where I know there is low clearance.
Quick Reply: CB Install Image
