Death Flash Info If U R Interested...
Old Dec 3, 2008 | 05:40 PM
Ram2K1's Avatar
Ram2K1
Post Death Flash Info If U R Interested...
...if not, leave your comments at the door and move on...
I have been researching more about the death flash crap, so hopefully this may help someone who has the same sticker as me. My sticker has no date on it, so I had to go by part #. This is what I found:
My sticker part # is 56040273AE, which is old...the new correlating # is 56040273AG.
That part # carries with it 5 possible TSB's which are:
18-006-02 REV C (Jun 02): Engine – Surge/Lack of Power in 3rd Gear/Erratic Shifts
18-011-01 (May 01): MIL Illumination (POO71 Battery Temperature Sensor Performance or P0135 or P0141 Oxygen Sensor Heater Performance)
21-004-01 (Feb 01): Overdrive Disabled to Improve Transmission Reliability During Cold Temperature Operation
25-001-01 (Feb 01): Generic Scan Tool May Not Display Certain DTC’s and Erroneous LDP Switch Fault
25-002-01 (Feb 01): Scan Tool Erroneously Displays P0000 For DTC's P1740 And P0461
So, since my truck was mfr in March 2001, I guess mine was flashed for one of the first two TSB's. I don't think mine has the death flash...it runs pretty strong, and the plenum gasket is not blown. Hope this helps someone out...
EDIT: If anyone knows more about this, here's everything on my sticker:
P/N P56040273AE
S/N TEH08512MEC3
HRB2AA (?)
SEQUENCE # 599920 (?)
Old Dec 3, 2008 | 06:17 PM
Laramie1997's Avatar
Laramie1997
Excuse my stupidity, but where is this "Death Flash" sticker supposed to be located?
Old Dec 3, 2008 | 06:22 PM
Vader's Avatar
Vader
Should be on the computer in the engine bay
Old Dec 3, 2008 | 06:55 PM
Ram2K1's Avatar
Ram2K1
^^^Passenger side firewall...
Old Dec 3, 2008 | 07:33 PM
mopowar's Avatar
mopowar
You have it. It was not a tsb. It was flashed that way straight from the factory. Pre mid 2000's will have the hand written software update sticker (if they do indeed have the death flash).
Old Dec 3, 2008 | 09:49 PM
Laramie1997
I assume you are talking about my truck then?
Hmm, never had a problem with power, but then again if it was always like that, I would not have known.
Old Dec 3, 2008 | 09:56 PM
BlueBeast2's Avatar
BlueBeast2
I won't have to worry about it soon
Old Dec 3, 2008 | 10:30 PM
dhvaughan's Avatar
dhvaughan
i think these two were the death flash that reduced the timing advance.
Date: Jan 26, 2001. 18-002-01
Date: Feb 28, 2003. 18-006-03. supersedes TSB 18-002-01 dated Jan 26, 2001.
http://dodgeram.info/tsb/2003/18-006-03.htm
i think this means that any flash after mid-2000 has it, and all late 2000 and 2001 models had it from the factory.
TSB index http://dodgeram.info/tsb/group_18.htm
__________________
Old Dec 3, 2008 | 10:35 PM
Ram2K1's Avatar
Ram2K1
Mr. Lucky here...jk. You'll truly have a beast when you're done. Mine is fine right now...gets decent gas mileage and pulls anything I need to pull, so I don't sweat it too much. May get a Superchips or Hypertech some day...not shellin' out $600 for SCT for a DD.
