what does no bus mean?
Old Feb 11, 2024 | 11:44 AM
  #31
jcatjeff's Avatar
jcatjeff
Angry no buss part check
check out this little discovery see the black spot in upper left corner......caused my no buss
Old Apr 27, 2024 | 01:30 PM
  #32
Shanksee24's Avatar
Shanksee24
I have a 99 Dodge Ram 1500. V6 magnum. All my gages go down and that no bus comes up where my mileage is. It's a wire and short in the circuit somewhere.. You can fix every short. You have, but also I notice I tap Is on my - Speedometer. - and it goes right back off.
Old Dec 2, 2024 | 01:36 AM
  #33
KernAutomotive's Avatar
KernAutomotive
Originally Posted by jasonw
Give me a break. Its not a design flaw, just a problem with a few old trucks. These trucks are getting a older now, so you will see some problems. Don't blame the manufacturer. Oh, and this is NOT a common problem with these trucks.
I would start with pulling the plugs off and cleaning all the contacts with some sort of electrical cleaner. Sounds to me like something isn't quite making constant contact.
It's not just an old dodge truck problem? I have a customer with a 2012 avenger, same issues, Dakota's, rams, jeeps? It's definitely a Chrysler Mopar issue thru many years. Only car I see with no buss codes or all kinds of other no comunication with PCM. Only car line that needs new PCM which is the fix most times. So I'd check the pin retention at the PCM for the ccd and bus contacts if that's good it's new PCM time.
pin retention refers to the connector ability to make a good connection on the pins of the ecm. You said you cleaned both sides, but does any of the tiny connectors look burned or spread apart more than the others?
Old Dec 8, 2025 | 10:20 AM
  #34
Brat3500's Avatar
Brat3500
[QUOTE=jcatjeff;3581919]check out this little discovery see the black spot in upper left corner......caused my no buss
Wow I found the same thing on mine. no bus and will not start. All new sensors and wire harness is good. Voltages and grounds check out. Did you just replace the display? Been working on mine for days....
