dodge ram transmissions
Old Dec 11, 2008 | 03:51 PM
  #41
MonteC's Avatar
MonteC
Originally Posted by Rex-TheDOGG
MonteC, it would be great if you could post up a list of mods and best practices that would help the longevity of our 46RE's. I know my previous owner did a transmission flush service before, but going by what I'm reading here, I don't think I want to risk that again.
What kind of list? Things to do with the transmission in the truck? Things to do while the transmission is out of the truck?
Old Dec 11, 2008 | 04:00 PM
  #42
Rex-TheDOGG's Avatar
Rex-TheDOGG
Things to do with the transmission in the truck -- definitely.
Old Dec 11, 2008 | 04:43 PM
  #43
jmhai's Avatar
jmhai
Originally Posted by MonteC
My inlaws live in Kannapolis. Im about three hours away from them in Summerville, SC.
Sweet ...From Asheville about 4 hours away...Alittle to far for a service (will probly do it myself anyways) but not a rebuild...
Old Dec 11, 2008 | 07:08 PM
  #44
99blueram's Avatar
99blueram
Hutch, Did notice a much firmer shift on low to mid throttle. Not any tire barking WOT though. My first complete rebuild with the help from this forum on what to do and not do. I was told that the quicker you get the cluthes engaged the less wear on them. Did find a bad sun gear and front bad, but everything rlse looked good for 93000 miles. Replaced converter just to have peace of mind knowing no crap would come out and mess up my rebuild. OD unit was in good shape even though it is suspect in many cases. Just a 2wd quad 5.9 truck that now is in need of a plenum gasket fix. With the info from here looks like not a problem. Thanks for asking.
Old Dec 11, 2008 | 09:02 PM
  #45
Kyole's Avatar
Kyole
Nope. It has nothing to do with the viscosity of the fluid. Your explaination actually sounds quite silly. Transmission fluid is basically hydraulic fluid, they share many similarities. In transmission fluid there are additives and detergents, to keep moving parts clean and the valves free. If you get a transmission with over 100k on it and no one has ever serviced it then the old fluid has lost all of the detergents and additives, they are all used up. So now all your left with is old basically hydraulic fluid.
When you do a flush service on a high mileage unit you break loose the crap that has built up in every crack and crevis in the unit. This crap floats around and hangs valves or clogs up the cooler lines.
If you do a simple pan drop and filter change and just add in new fluid to replace what came out of the pan you will help the transmission.
Please stop perpetuating myths. I have never built a transmission that was serviced properly.
in my experience( im a tranny tech at a local chevy dealership, maby thats why), ive seen 700r4's come in with about 120k miles and they complain of slipage or absolutely no reverse/4th gear whatsoever and they have all said they've changed the fluid and filter within 200 miles. now, on the otherhand. ive seen 4L80's come in with 270,xxx+ for oil change/27 point inspection that have NEVER had the trany fluid changed and they still shifted almost perfect, minus a little delay on the shift times. Maby thats just with chevys trannys. im still learnin all this new confangled chrysler stuff not tryin to shoot down anyone, just what ive seen.
Old Dec 12, 2008 | 06:55 AM
  #46
MonteC's Avatar
MonteC
Bud its all the same stuff. The theory and mechanics behind them are pretty much the same.
If they 700r4's have no reverse or 4th then its a good chance the sunshell is broken, nothing to do with fluid. How many 120k 700r4's are out there? They stopped making that transmission over 20 years ago.
Old Dec 12, 2008 | 07:17 AM
  #47
Kyole's Avatar
Kyole
I know that is all the same stuff. what im sayin is that maby these transmissions have a higher tolerance for sh!+ in them.
the sunshell was fine. the clutch packs were darker than our prez and ive seen probibly about 6 or 7 that have less than 140k on them. i just put a shift kit in one a couple of weeks ago in a WS6 that had 81k on it...
Old Dec 12, 2008 | 10:11 AM
  #48
MonteC's Avatar
MonteC
The 700 and 4l60e dont have a tolerance for much of anything. But if they changed the fluid then something happened then they had other problems. 120-140k is pretty good for a 700r4. The reason why people do services so late, at 120 or 140 is because something is causing a problem. So they change the fluid in hopes that the problem will go away. But changing the fluid for the first time on a neglected transmission will not fix any problems. The problem will still be there and in most cases will die on them shortly after. So everyone blames the new fluid.
If you were familiar with the fluid circuits and how a transmissions clutch packs apply and how the fluid is routed and what controlled them you would know this. The thought that new fluid will kill an old transmission is well to be frank, pretty dumb.
Old Dec 13, 2008 | 12:37 AM
  #49
Jr. Mechanic's Avatar
Jr. Mechanic
Had the 700R4 in my Camaro built with every part my transmission guy could throw in it
Old Dec 13, 2008 | 10:28 AM
  #50
MonteC's Avatar
MonteC
They are a pretty good transmission once you get them rebuilt right. The biggest problem with this transmission was the lack of the publics knowledge on the TV cable system. These transmissions were super sensitive to the TV cable setting and people would either mess around with it and get the wrong setting or not get it adjusted for 100000 miles and burn it up from it being out of adjustment.
