pushrod through rocker
Old Dec 10, 2008 | 05:50 PM
Keegan's Avatar
Keegan
Default pushrod through rocker
From my plenum leak aftermath thread...
WHAT WOULD CAUSE A PUSHROD TO GO THROUGH A ROCKER???
1. Bad / low oil?
2. A bad misfire ?
3. A plenum that leaked for years on that particular cylinder?
Old Dec 10, 2008 | 08:03 PM
dhvaughan's Avatar
dhvaughan
low oil doubtful, that would affect a lot of moving parts.
sludge blockage in lifter or push rod blocking oil supply more likely.
weak metal in the rocker maybe.
Old Dec 10, 2008 | 10:23 PM
Keegan's Avatar
Keegan
Have a look at these pics!!!
The rocker on the left is what it should look like.... just a small hole in the middle
The rocker on the left is what it should look like.... when its been destroyed!!
The push rod came out wedged inside the rocker... I pulled it out and it fell to pieces.
Old Dec 10, 2008 | 10:34 PM
dhvaughan's Avatar
dhvaughan
i bet it'll run a lot better with a new one.
Old Dec 10, 2008 | 10:37 PM
Keegan's Avatar
Keegan
It's like a brand new truck! It was quite a treat since it ran like crap since I bought it in Feb.
Old Dec 10, 2008 | 11:21 PM
Ram2K1's Avatar
Ram2K1
Did you get the HS 1.7's?
Old Dec 11, 2008 | 08:47 AM
Keegan's Avatar
Keegan
Just oem. I only replaced the parts you see in the picture.
Old Dec 11, 2008 | 10:22 AM
talon6's Avatar
talon6
man,you would have thought you had a race truck if you would have went with the h.s. 1.7 rockers then.
i keep hoping that stuff like this would happen to my truck,like cracked head and,trans go out so i can justify spending the money pumping it up.
Old Dec 11, 2008 | 10:54 AM
Silver_Dodge's Avatar
Silver_Dodge
Did you have a moment that the truck rev'ed up to an abnormal rpm for any reason?
Maybe a bad lifter?
Old Dec 11, 2008 | 11:13 AM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Very strange. Did you ever find the rocker dimple that popped off? It made a perfect circle. Intake or exhaust valve? The only thing I can think of is someone floated the valves and a piston slapped into it.
