a little help needed
Old Dec 14, 2008 | 10:41 PM
redneckokie1's Avatar
redneckokie1
Default check the exhaust
one quick problem to eliminate is a plugged converter. a partially plugged converter will allow the engine to run for several minutes until it kills the engine. if you get the truck started, go to the exhaust and see if it's flowing freely. sometimes it takes a few minutes for the converter to start restricting.
i had a truck that would run for almost exactly 5 miles and would die within 100 yards of every previous failure. i thought aliens had a beam there.{G}
Old Dec 15, 2008 | 08:39 PM
19ramslt98's Avatar
19ramslt98
Ok i changed the crank sensor started it up let it run for 20 mins. and shut it off and restarted several times then took it out for a drive for about 5 miles and it ran great
i will try it again tomorrow just to see but i think i got it.
Old Dec 15, 2008 | 09:32 PM
dhvaughan's Avatar
dhvaughan
and the winner is.....
Originally Posted by pro tech
My money is on a bad crank postion sensor.....
Old Dec 16, 2008 | 08:50 PM
19ramslt98's Avatar
19ramslt98
yes thank you very much
