Engine Stalls while in drive at stoplights in cold weather
Old Dec 15, 2008 | 11:40 PM
fchadly's Avatar
fchadly
Default Engine Stalls while in drive at stoplights in cold weather
I have a 1994 Dodge ram 1500 3.9L V6 auto; in cold weather (-6 to 10 degrees) after a decent warmup, my truck will stall out at stops while in drive as soon as I take my foot off the accelerator like when I am waiting at a stoplight or as I am braking to less than 15mph while I am turning a corner. To counter act this until it straightens up, I brake with my left foot while I keep a slight idle with my right to keep truck from stalling out at stoplights. After about 20min in operating temperature, the engine finally stabilizes and stays running normally while I am stopped or doing braking manuevers while turning. Any ideas on what is causing the stalling in the first 20min of drive time?
Thank you,
Chad
Old Dec 16, 2008 | 01:14 AM
dodge15004x45.9's Avatar
dodge15004x45.9
thick fule need new spark plugs and wires or bat or clogged cat im not sure just a few thing to think about
Old Dec 16, 2008 | 10:49 AM
Kindschi's Avatar
Kindschi
My camaro did the same thing, Turned out to be a weak alternator. Maybe something to look at since Autozone does a free check.
Old Dec 18, 2009 | 05:45 PM
cortezboston's Avatar
cortezboston
Any ideas on this? My 1996 Dodge Van is doing the exact same thing.
Old Dec 18, 2009 | 05:59 PM
95RAM360's Avatar
95RAM360
bad upstream 02 sensor? IAC?
Old Dec 18, 2009 | 06:02 PM
cortezboston
Thanks, I'll check into these and see if either may be the culprit.
Old Dec 18, 2009 | 06:06 PM
95RAM360's Avatar
95RAM360
take out the 02 sensor at the CAT, if it "relieves pressure" the cat is clogged, and while its out look at the 02 sensor and see if the plenum problem got to it and built up carbon/oil n it.
Old Dec 18, 2009 | 06:12 PM
cortezboston
Thanks again, now I have a good place to start.
Old Dec 19, 2009 | 03:48 AM
Dodgeski's Avatar
Dodgeski
A common problem for dodges is the intake manifold gasket. I have a 5-speed manual and it used to stall immediately after starting in the cold weather. I found out after a suggestion from a local mechanic that there was a leak in the intake manifold gasket. easy fix and worth a try.
