can't get a radio to work.
Old Dec 16, 2008 | 03:15 PM
guitarking135's Avatar
guitarking135
Default can't get a radio to work.
So I got my truck with no radio or speakers in it and the dumb *** spliced into the factory side of the harness to have his subs. asinine I know anyways I have acouple of stereos laying around one of which I know works fine. The problem I have is i cant get either to power on inside of the truck. The two power wires never got touched on the factory side and they both have power. But neither radio will turn on. Is there something I'm missing here. I bought a new wiring harness and soldered it in and still nothing any ideas?
Old Dec 16, 2008 | 03:43 PM
dodgeram07's Avatar
dodgeram07
i'm not really sure of what your saying........(well i understand a little),,sorry
but the radio needs power on the red and yellow wires and a ground on the back wire, to power on...
ingnition wire(red)
battery wire(yellow)
the red wire goes to the fuse box then to the ingnition then to the main fuse box then to the batterypower and the yellow goes to the fuse box then the main fuse box.
if you what to radio to play without the key in the ignition and on,,, you can have the red wire go to power (no switch = no ignition)
so really just to get the radio to power on, the red and yellow need power.
i really hope this helped.
Old Dec 16, 2008 | 06:31 PM
kringl's Avatar
kringl
thing i found wierd on the dodge was the ground black wire seperate from the harness pluged into a tab on the radio chassis if you have power at the red and yellow chech that ground for mine i just soldered a male spade to the black wire and pluged into the conector from the truck if its still there
Old Dec 16, 2008 | 10:48 PM
guitarking135
ok so on my factory harness I have a grey conector and a black one and a black and white one with two wires what does the small two wire one go to? is that the ground you were talking about?
Old Dec 17, 2008 | 09:12 PM
kringl's Avatar
kringl
dont remember but looked up in manual shows ground as balck/dark blue wire but if having problems just to troubleshoot grab a chassis ground for the stereo ground and see if it powers up. will show you if the ground is really the problem your having before splicing back together
Old Dec 17, 2008 | 11:43 PM
dodgeram07's Avatar
dodgeram07
there was a ground wire that when form the factory harness to the back of the radio
so you should have two conectors and a ground that can be bolted the the back of the radio..... that the way it was on my 95
Old Dec 18, 2008 | 12:09 AM
guitarking135
hmmm ok I'll piddle with it tomorow
Old Dec 19, 2008 | 08:50 AM
APA228's Avatar
APA228
The small white connector with 2 wires should be for steering wheel control for the radio. It plugs into the radio on the back right side.
