Oil Pressure again
Old Dec 17, 2008 | 03:56 PM
  #21
pro tech's Avatar
pro tech
Question Uh oooohhh..
Hope you didn't toast your bearings....or worse.
You still running the same engine oil that you dumped that can of seafoam into???
Yikes.....!
  #22
PurplDodge's Avatar
PurplDodge
Originally Posted by vmann
turned it on this morning and didnt sound good.
We told you not to drive it!
Old Dec 17, 2008 | 04:35 PM
  #23
zman17's Avatar
zman17
Retired Moderator - RIP
And just to clarify, when I said do it at school and get a ride , I was under the assumption that you were already at school, but then I looked at your sig and realized the time zone difference from where I am to where you are. Either way, driving it was a major NO NO ! Until you figured it out.
Old Dec 17, 2008 | 06:15 PM
  #24
vmann's Avatar
vmann
i didnt drive it at all. The gage light came on just as i got home the other day and it hasn't been driven since. I got a ride from a friend. It is now at the dealership and my uncle will call me when they know whats up. Ill keep it updated.
Old Dec 17, 2008 | 09:47 PM
  #25
JimkDaAdtman's Avatar
JimkDaAdtman
That's what my engine did.. When my tranny blew, the motor revved a bit too high, and then the check gauges light came on, and the oil pressure went to 0, could be a blown rear main, could be the oil pump blew up, could be the rebuild wasn't done right, and a rod blew through the block.. Could be many things.. glad your having them check it out.. Although, sounds like your a bit hard on her, maybe she couldn't take it anymore and commited suicide..
JimK
Old Dec 18, 2008 | 07:52 AM
  #26
vmann's Avatar
vmann
haha no way am i hard on her. I drive pretty easy just because gas is so expensive and im broke lol
Old Dec 18, 2008 | 11:22 PM
  #27
vmann's Avatar
vmann
Ok so the gears in my oil pump got busted and they are putting in a new pump and gasket. Its going to come up to about 400 bucks customer price. Should be around 200 - 250 employee price. They checked the engine for me and said there was no damage to it and that it was smart not to drive it.
Old Dec 18, 2008 | 11:29 PM
  #28
JimkDaAdtman
thanks.. That may be what's wrong with mine... I have to tear into it to find out.. just wont be able to yet... Nice you got someone like your uncle to do it on the cheap..
I need me an uncle..
JimK
Old Dec 18, 2008 | 11:47 PM
  #29
dodgeram07's Avatar
dodgeram07
if you would of did it yourself it would of been about 60 bucks... but at least it's fixed now
Old Dec 19, 2008 | 12:05 AM
  #30
TRG's Avatar
TRG
You should consider yourself lucky. Very lucky. Lesson learned is if you ever see an oil light/gauge go to 0 - jam that bitch into Neutral and kill it!!
