what size is your pipes?
Old Dec 18, 2008 | 03:33 PM
minis2003's Avatar
minis2003
Default what size is your pipes?
looking to get a new exhaust for my 5.2L and a stock engine
what size pipes would be a good size with the best deep sound
single 2.5 or 3"
or dual 2 ? 2.5? 3?
Oh yes a new cat will go on to at the same time
Old Dec 18, 2008 | 03:39 PM
Ram2K1's Avatar
Ram2K1
I think for single, I would go with 3". For a dual, I would go with 2.5". It's up to you. Either would sound good. I kind of like the 3" single set-up myself.
EDIT: Forgot to mention, I have a single 2.5" with a Thrush glasspack and side exit and it's deep toned.
Old Dec 18, 2008 | 05:44 PM
xskylinedx's Avatar
xskylinedx
I'm running a single 3" and I like it.
If you want duals you might want to look at 2.25"
Old Dec 18, 2008 | 05:50 PM
dodgeram07's Avatar
dodgeram07
are you wanting true duals?,,, or a muffles with duals coming out?... also if you go to big of a pipe you will lose bottom end power..
Old Dec 18, 2008 | 06:02 PM
dodge15004x45.9's Avatar
dodge15004x45.9
how so i put i custom catback on my truck it comes out in front of my passenger rear tire
Old Dec 18, 2008 | 11:16 PM
minis2003's Avatar
minis2003
well i am not sure if i want a true dual or just two pipes out the rear.
i heard more trucks with a good deep sound that is not to loud then a single
out the side. so i think i might be going towards a dual setup
Old Dec 19, 2008 | 02:09 AM
jasonw's Avatar
jasonw
Site Moderator
True duals, just in case (some people get confused), means the pipes NEVER touch each other. Two mufflers (or none), two converters (or none), one pipe from each manifold/header to its own exit.
No offense to any of you guys. Reason I explain this is I've seen a recent increase online of people claiming they have true duals with a single muffler, converter, and/or y-pipe involved. It makes me shake my head, I thought it was common sense.
Oh, and I have a single 3" pipe and I am very pleased. y-pipe from manifolds to 3" converter to 2.5" pipe to 2.5" muffler to 2.5" pipe that expands to 3" right before the bend to exit out at stock location.
Old Dec 19, 2008 | 03:39 AM
TIMIDONE's Avatar
TIMIDONE
I want true duals...as u stated...gonna cost time and money to do so!
Old Dec 19, 2008 | 08:24 AM
iwhitne's Avatar
iwhitne
3" in/out flowmaster original 40 series
