Remote starter 99 Ram 2500
Old Dec 19, 2008 | 06:19 PM
dksob81's Avatar
dksob81
Default Remote starter 99 Ram 2500
I am getting ready to install a remote starter system on a 99 dodge RAM 2500, I got the wiring information and for the starter wire it says "MUST ADD RELAY FOR REMOTE START", what is the relay for?
I have installed about a dozen remote starteron many vehicle and never once did any of them call for a relay for remote starting.
Old Dec 21, 2008 | 04:29 AM
jasonw's Avatar
jasonw
Site Moderator
Not 100% for our Dodges, but it may have something to do with the factory keyless entry (so you can still use it in addition to the starter's).
On my wife's 2004 Jeep Grand Cherokee 4x4, Jeeps come equipped with smart key and a starter immobilizer (so if you aren't using the smart key to turn the ignition, even if they key fits, the car won't start), so my wife's Jeep required two relays, one for that and one for the factory keyless.
Old Feb 15, 2009 | 03:28 PM
alberto coronado's Avatar
alberto coronado
Default remote start cranks will not start
i have a 98 dodge ram 1500.factory remote will crank too long ,as if the starter is sticking then shuts off. then it tries again.
it will start using the key.
on a cold start you have step on accelerator to stay running.
any ideas
Old Feb 15, 2009 | 10:02 PM
dblj16380's Avatar
dblj16380
I've got a 99 1500 and I put a remote start on mine and there were a few relays that I had hooked up (I think 4 of them) but they all came with the kit and were already all wired together in the harness. As far as an external one, that is the only thing I can think it would be used for is a keyless entry setup. If you don't have keyless entry, then you should be able to skip this step.
To be sure, I would e-mail the company with your question and see what kind of response they come up with.
Old Feb 16, 2009 | 07:11 AM
dksob81's Avatar
dksob81
Thanks, I have installed alot of systems and I ussually just go onto the12volt.com to get my wiring information and this is where I read about the relay use for remote starters. maybe it's nothing.
I know about using the relays for door locks and stuff, but didn't understand what it would be used for on remote starting.
