Sport fog lights
Old Dec 19, 2008 | 10:25 PM
oiler's Avatar
oiler
Default Sport fog lights
How do I turn on the fog lights on my 99' sport? I read the manual but found no info on it. Thanks.
Old Dec 19, 2008 | 10:29 PM
360magnumram's Avatar
360magnumram
I would imagine that you turn them on by pulling on the headlight switch. If you have the dial just turn it to headlights on position and physically pull on the switch.
If they dont turn on you may have blown bulbs or bad wiring.
If you have the **** thing i believe you just pull it all the way out and they should turn on
Old Dec 19, 2008 | 10:44 PM
CSXfan's Avatar
CSXfan
360magnumram is correct, you just pull the *** out.
Old Dec 19, 2008 | 11:15 PM
vmann's Avatar
vmann
i hate the **** pull out ones. im always scared that im going to break it
Old Dec 20, 2008 | 12:54 AM
dodge15004x45.9's Avatar
dodge15004x45.9
i have after market hellas and i have my switch on top of my tran. tunnel mounted on that black plastic cover.
Old Dec 20, 2008 | 02:12 AM
Laramie1997's Avatar
Laramie1997
what??? have the same on mine and have abused it for years never had a problem.... yet....
Old Dec 20, 2008 | 08:21 AM
WaynesWorld's Avatar
WaynesWorld
also make sure the hi-beams are off because the fogs wont light up with your brights on.
Old Dec 20, 2008 | 09:58 AM
meanwhitemopar's Avatar
meanwhitemopar
the way to turn them on period is the switch on the right side of the dash bezel, there is a small push button that has the fog light symbol on it. make sure you have the high beams off, or just turn your parking lamps on ( first spot on that pull switch) and they should turn on, if not its your bulbs, they are like 8 bucks a peice at autozone, and its twist to remove from the back of the bumper and unplug the wires with the little plug with a tab on it. reverse for install
Old Dec 20, 2008 | 10:45 AM
Viper37's Avatar
Viper37
Only on the older Rams. The newer ones are combined into the headlight switch.
Old Dec 20, 2008 | 11:44 AM
chet's Avatar
chet
not to hijack but one of mine is busted and the other one got water in it, so neither one works now. Where can i get them that just plug back in to the stock wiring harness or should i just put new ones in and run a switch ?
