New to Rammin, how can I tell my tranny?
Old Dec 21, 2008 | 01:28 PM
MudRam99's Avatar
MudRam99
Default New to Rammin, how can I tell my tranny?
Hi all, I'm new to Ramin, just aquired a 99 Sport 4X4 and was wondering how can I tell which model tranny is in this unit?
Thanks
Muddy Ram
Old Dec 21, 2008 | 02:30 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You got a 46RE. If it seems like it's working fine. Change the fluid and filter(don't have it flushed) Use ATF+4 fluid, adjust the bands, don't use OD under 60 mph or when towing, add a trans cooler,remove the check valve and you should be good to go.
And here is a good write up on the check valve by some wanna be on this site! LOL JK AIM https://dodgeforum.com/forum/2nd-gen...ve-delete.html
Old Dec 21, 2008 | 02:34 PM
vmann's Avatar
vmann
problem solved.
Old Dec 21, 2008 | 05:34 PM
MudRam99's Avatar
MudRam99
Thanks very much, well I have the diaq code P0740 and wanted to read the info about the Torque converter, it's clutch and related systems. This code seems to be the least specific of them all, just a "malfunction of the TCC
Old Dec 21, 2008 | 10:11 PM
aim4squirrels's Avatar
aim4squirrels
try the FSM:
http://www.rm-indy.com/wavefiles/2001ramsrvcmanual.zip
Old Dec 21, 2008 | 10:13 PM
aim4squirrels
LOL, I'm a total fraud! I admit it!
Old Dec 22, 2008 | 01:56 AM
jasonw's Avatar
jasonw
Site Moderator
Yup, 46RE. 1994-1995 have 46RH if you have one of the V8s, 42RH if you had the V6. 1996+ have 46RE if you have the V8s, 42RE if you have the V6.
Old Dec 24, 2008 | 03:19 PM
MudRam99's Avatar
MudRam99
Default Thanks
Now that I know my transmission model I will research further, and compile a description of whats going on with it, then chase down that professional transmission guy on here and see if he can diag it.
Old Dec 24, 2008 | 03:27 PM
zman17's Avatar
zman17
That would be MonteC. Post your problem and he will most likely chime in.
