Do a search here because there is a couple ways to check it. Visually or vacuum.Here is the vacuum method.(which I think is better)http://dodgeram.info/tsb/2000/09-05-00.htm
Ok, so I drove the truck another 1000 miles and the rough idle came back. I got fed up and pulled a plug, and sure as chit the damn thing was back to .6 gap. I am done with plat plugs went and got these instead
I usually use Champions in my vehicles but have used Auto-lite with no problems. Never tried the platinum ones.
Back when we had point ignitions we figured on a complete tune up every 10 to 12 thousand miles. Also when I started driving a grease job and oil change every 1000 miles.
