high idle causing bad gas milage
Old Dec 28, 2008 | 04:52 PM
awery19's Avatar
awery19
Default high idle causing bad gas milage
my truck is idling at 1500 to 2000 rpm it has a check engine light code p0505 which is the iac system i changed the iac cleaned the throttle body and checked the wiring and nothing i can hear a leak from the throttle body around the iac but i dont know what it could be and from all this im getting 6mpg. can anyone help with this?
Old Dec 28, 2008 | 05:21 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Replace the TPS!
Old Dec 28, 2008 | 05:33 PM
awery19's Avatar
awery19
tps and iac are brand new
Old Dec 28, 2008 | 05:37 PM
OneBadKota's Avatar
OneBadKota
Take some brake/parts cleaner and spray around the vacuum lines. One might be cracked, or holey.
Old Dec 28, 2008 | 08:18 PM
awery19's Avatar
awery19
yeah but why would the leak come from near the iac in like that chamber in the throttle body behind the plates. I can feel the are getting sucked into there and I don't know if somethings supposed to be there or not
Old Dec 28, 2008 | 08:24 PM
OneBadKota's Avatar
OneBadKota
You said you changed the IAC, right? Did it start happening right after? Maybe something popped off, or didn't get hooked back up?
The best thing I can think of is to take a good, full-sized photo of it and post it. I'm sure someone might see something out of the ordinary.
.02
Old Dec 28, 2008 | 09:05 PM
ophidia's Avatar
ophidia
Perhaps the o-ring did not get installed with the new IAC?
Old Dec 29, 2008 | 09:23 PM
awery19's Avatar
awery19
it happened after the new iac had been in there for about a month and then i changed it again just incase that one had already gone bad. and im not sure if it came with an o-ring but why would it affect it a month after?
