truck jump
Old Dec 29, 2008 | 12:29 AM
contractorben's Avatar
contractorben
Default truck jump
Hey Guys,
I have a 2001 ram 1500 V8 5.9 auto trans. club cab 4x4, it has 86,000 miles on it. The truck seems to jump every once in a while maybe every 50-70 miles to be specific. If I sit in drive with my foot on the brake it will jump also. I havent watched the rpms to see what they are doing due to the fact its so un pedictable. When it jumps it will only be for a second then run fine, also seems a bit slow for 5.9.
Thanks for any help,
Ben
Old Dec 29, 2008 | 01:12 AM
itsdaveonline's Avatar
itsdaveonline
Originally Posted by contractorben
Hey Guys,
Ben
Its probably a bad ignition coil...or a faulty spark plug, Id imagine you can test the coil using a digital multimeter and the ohm function. I have had the same problem occur on some maximas.
Old Dec 29, 2008 | 01:51 AM
jasonw's Avatar
jasonw
Site Moderator
If daveonline's advice leaves you none-the-wiser, I'd also check the spark plug wires.
Old Dec 29, 2008 | 04:33 PM
contractorben
Thanks, Guys will try today.....
Ben
Old Dec 29, 2008 | 11:14 PM
contractorben
It worked it was #6 spark plug, thanks a ton
Old Dec 29, 2008 | 11:39 PM
jasonw's Avatar
jasonw
Site Moderator
Glad we could help. Thanks for posting the resolution!
