clearance lights
Old Jan 3, 2009 | 05:51 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Default clearance lights
I know that there was a recent thread about clearance light but how do i know if my truck has a pre wired connection for clearance light. If I do would it be as simple as plug and play kinda deal.
Old Jan 3, 2009 | 11:41 PM
dodge15004x45.9
anyone
Old Jan 3, 2009 | 11:44 PM
jmhai's Avatar
jmhai
I would not think so, but I have been wrong before...
Old Jan 4, 2009 | 12:33 AM
HammerZ71's Avatar
HammerZ71
Take off the pillar post on the passenger side and look for a wire connector. It'll take you about a minute to get the pillar off.
If not, it's no big deal, you can take the wire out of one of the existing grommeted holes in the fire wall and wire it directly to running lights at the fuse box.
Old Jan 4, 2009 | 12:39 AM
dodge15004x45.9
If not, it's no big deal, you can take the wire out of one of the existing grommeted holes in the fire wall and wire it directly to running lights at the fuse box.[/QUOTE]
And how would i do that??
Old Jan 4, 2009 | 08:18 AM
zman17's Avatar
zman17
Retired Moderator - RIP
https://dodgeforum.com/forum/2nd-gen...o-install.html
Old Jan 5, 2009 | 12:57 AM
vmann's Avatar
vmann
I ran my wires from the lights down the driver side pillar and connected it right into the switch. Just used a wire tie so that i wouldnt have to cut into factory wires. Works fine.
im the one who just installed mine.. see sig picture
Old Jan 5, 2009 | 01:42 AM
dodge15004x45.9
i know that lol i found a guy on here who has a hole set up from a factory 2500 ram. What did you use to seal the holes in your roof? i just wanted to know if my truck had the factory plug did yr? i have an 01 1500. which style do i buy there is 2 for dodge.
Old Jan 5, 2009 | 06:48 AM
PurplDodge's Avatar
PurplDodge
Dodge used rubbers
Old Jan 5, 2009 | 01:50 PM
vmann's Avatar
vmann
i just screwed right into my roof. I used silicone to seal whatever was left. I only drilled holes big enough for the wires to tightly fit through.
