Old Aug 13, 2015, 08:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Just got cab lights.. no idea how to install
Old Dec 31, 2008 | 01:12 AM
vmann's Avatar
vmann
Default Just got cab lights.. no idea how to install
Ok so i got my orange cab lights today and lucky for me they came with no instructions. I have pictures on everything that came with them. I found this write up on how to do them.. should i pretty much follow this? http://www.*********.com/forums/show....php?p=2248958 (replace the stars with dodge_talk but no _)
oh and does anyone have the measurements for placement of them? i've heard that the measurements are different than the 3rd gens etc.
comments, ideas, etc..
Old Dec 31, 2008 | 07:03 AM
HammerZ71's Avatar
HammerZ71
There is a DIY in that section on this forum that is so well written, it's now the docs that come with Recon's Cab Lights. It would be nice if a kit other than the Mopar one came with a template though.
It's not a hard install at all, you just have to get over the fear of drilling through your roof...
Old Dec 31, 2008 | 09:46 AM
Magnumpwr16's Avatar
Magnumpwr16
It is not hard at all....the ones you see on my truck in my sig pic I put on a year ago and it was so easy. If you take your headliner down on the ceiling of the truck you'll see the pre-marked holes for where there lights would be if they had come from the factory with them. No need to measure or anything. Run the wiring down behind all the upper trim and everything and find a place for you switch (I just wired mine to my headlight switch so that when i put on my parking or parking/headlight they come on). See if that helps.
Old Dec 31, 2008 | 09:58 AM
pcfixerpro's Avatar
pcfixerpro
Do a search for dodge ram cab light install on the internet and there are a few out there (I looked about a year ago for my friend). Once you remove your headliner there will be holes in your roof to show you where to place them. ( you will see what I mean once you remove the headliner) My buddy used two hole saw's to get it exactly perfect. One was the exact width of the hole thats in the roof, and only used it to drill the pilot hole. By doing so he now has a small pilot hole in the exact center where the light should be. He then took the other hole saw and found the size required for the light, and used the pilot hole that he made with the last cut, to place him in the exact center and then cut it out. Another note to think about would be about not using that switch that came with it. We tied his in by running the wire down the a piller and tie into the running light wire. (look in shop manual for wire diagrams, or use a volt meter if your lazy into the back of the switch. You will need to remove your bezel for this, and remove the light switch screws. Use a tap splice like you were given for the cab lighst to tie into the running light wire.
Edit
Darn it that always happens! I take forever to make a response and someone posts by the time I finish :/ Anyway here is a night shot of the lights. He has the clear recon, but its the same principal. Wish ya luck!
Old Dec 31, 2008 | 02:01 PM
vmann's Avatar
vmann
im not worried about drilling through the roof as much as i am getting the lights aligned. Ive seen people do the install themselves and the slightest misplacement ruins the look of the vehicle. Im going to go pull back the headliner to see if the marks are there. And about running them to my light switch.. i've never messed with it so i will most likely install the lights with the switch provided and mess with that later.
oh and i did the search and didn't find the write up.
Old Dec 31, 2008 | 02:09 PM
HammerZ71's Avatar
HammerZ71
You didn't look to hard, about 5 seconds using the search function in the DIY section under "cab lights".
https://dodgeforum.com/forum/diy-do-...ram05baby.html
The pics went bye-bye when the software upgrade toasted the albums, but the written step by step is there.
I forgot about the dimples in the roof on 2nd Gens., 3rd Gens ain't got, at least not 1500s. We do have the connector for them in the passenger pillar post though. Not sure if it was there in 2nd Gens. If so, wiring them for power and to come on with parking lights is a snap...
Old Dec 31, 2008 | 03:05 PM
vmann's Avatar
vmann
that write up is the exact write up i posted. the one i posted still has pictures though. it says its for 3rd gens
Old Dec 31, 2008 | 05:02 PM
LegendKiller89's Avatar
LegendKiller89
It ain't that hard, pretty simple took me about an hour, most of that was drilling to make sure I was exact lol.
Old Dec 31, 2008 | 05:22 PM
vmann's Avatar
vmann
i can drill and do all that fine. Its just the wiring. I tried to connect it to make sure the lights work and nothing. The switch lit up but the light did not. Im a little confused because there is only a black wire coming out from the lights which i am assuming is the grounder. I even tried connecting that black wire to the harness wire that came with it.. still nothing.
Old Dec 31, 2008 | 05:36 PM
dodgeram07's Avatar
dodgeram07
black is power(werid) and the srew that goes in the roof is the ground... tyr gounding the srew and power on the black and see if it works.
