Tranny problem again
Old Jan 5, 2009 | 02:16 PM
pavement_hater's Avatar
pavement_hater
Default Tranny problem again
A little background. About 8-9 months ago got a code and tranny went into limp mode. After replacing the gov. pres. solenoid and sensor everything was fine again until last week.
In the middle of a 4k mile round trip vacation my tranny started to hiccup. Now and then it would feel like it shifted out of OD for a second and shift right back in. It only did this occasionally for about 3/4 of my trip. About half way home the check engine light came on giving me a p1764 code and the tranny is in limp mode again. Is it believable that the sensor or solenoid could already be bad again in 8-9 months? Probably 10k miles on them.
Old Jan 5, 2009 | 07:32 PM
MonteC's Avatar
MonteC
Its possible. If the transmission is making a lot of metal that is floating around in the fluid then it wouldnt be that hard to believe. That solenoid attracts ferrous metal and the more that gets stuck to it the worse the solenoid operates. Take it out and clean it and put it back in and see what happens.
Old Jan 6, 2009 | 01:45 AM
pavement_hater
Here's a crazy update. Drove it to work today shifting for it the whole way. (7 miles)
When I left work the first thing I noticed was the check engine light was out and the tranny was no longer in limp mode. I drove around for about a half hour to see if it would come back on. So far it hasn't. I guess time will tell whats going on.
Old Jan 8, 2009 | 10:05 PM
pavement_hater
Still intermittent. Light came back on Tuesday and stayed on until today. Now its out again. been having a ground issue with a couple wires under the hood. I'm starting to think that this might be my problem.
Old Jan 12, 2009 | 01:56 PM
LegendKiller89's Avatar
LegendKiller89
I replaced my gov pressure solenoid and transducer in August, and it went the day after christmas. F***ing Mopar tranny parts man.
Old Jan 12, 2009 | 10:08 PM
helms's Avatar
helms
im having the same problem, but mine has lasted a little longer, 18 months. but now its acting up again, but its been good for a week straight. i had the tranny overhauled last year and serviced today, they said the pan wsa clean. so ill wait untill it messes up again before i replace it
Old Jan 15, 2009 | 08:59 PM
pavement_hater
I may have found my problem. The light has come on and gone out a couple times. I have also been dealing with a bad ground issue with a couple wires that ground to the engine. They are the wires that ground at the top of the power steering bracket. I fixed the ground wire problem yesterday and since the tranny has worked right ever since. The light has gone out and so far has not come on. I bought the sensors that I now may not need. But at least I'll have them for when they go bad. I'll let you guys know if the issue comes back. Today while rotating the tires I just found out I now have a front wheel bearing going out.
Old Jan 16, 2009 | 02:30 AM
helms's Avatar
helms
time for a dynatrac hub conversion! im waiting for mine to fail so i can get my new ones
Old Jan 16, 2009 | 07:19 AM
txredneckmedic's Avatar
txredneckmedic
What i would do just as a preventive maintance issue is change the tranny filter and fluid
Old Jan 16, 2009 | 05:15 PM
pavement_hater
Now the light is on again but the tranny is shifting fine. It is not in limp mode. This thing is crazy.
