I need major advise......
Old Jan 6, 2009 | 02:05 PM
hemiboy_blue's Avatar
hemiboy_blue
Default I need major advise......
I bought a 95 dodge ram 1500 with the 5.9 360. I am wantin to put an intake, heads, cam and headers on it. i cant find anything for this truck. it is throttle body and its quick like it is cause its a single cab with low gears. Please help
Old Jan 6, 2009 | 02:12 PM
Silver_Dodge's Avatar
Silver_Dodge
Try the search feature. All those mods have been covered tons on this forum.
Old Jan 6, 2009 | 02:21 PM
hemiboy_blue
dude, not to be an *** but i dont ever know how to use this web site. i just got on it today. everytime a search for stuff i never find what i want. just stuff that it says that i need lol
Old Jan 6, 2009 | 02:49 PM
Laramie1997's Avatar
Laramie1997
if you cant find the search at the up right hand corner of the page then I suggest you just flip through the forum pages for ideas. BTW those are the bottom of the page on the right hand side.
Old Jan 6, 2009 | 02:58 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Here's are some good vendor sites to get an idea of what you want:
http://www.hughesengines.com/Index/index.php
http://www.krcperformance.com/krc/
That should get you started.
Old Jan 6, 2009 | 03:06 PM
RM_Indy's Avatar
RM_Indy
Welcome aboard
Have a look at the links below. How much hp do you want to increase?
Fastman 52tb is reasonable price and helps a fair bit and intended for a 360.
http://thefastman.com/Throttlebodies5x.asp
KRC has some pretty good cams IMHO. If you go with a big cam, it will require a lot of changes.
http://www.krcperformance.com/krc/in...mart&Itemid=26
M1/2bbl works pretty good but will cost some low end torque. Really need a higher stall tc with m1 & a cam IMHO. 2500 stall would be good, unless big cam, will need higher stall. KRC & Hughes sell them. Oh, just noticed, 95, you will need the egr version which is not cheap.
Hughes Heavy Duty heads a good choice and fair price.
?? Seems their site is down for some reason,,,,,,
Can also find these heads on Ebay. Sometimes listed as EQ Heavy duty heads.
Old Jan 6, 2009 | 03:37 PM
dodgeram07's Avatar
dodgeram07
for the INTAKE MANIFOLD, if that was your talking about, you need to get one with a egr valve also the header need a egr port,,,
so the intake and header NEED!! a egr valve, do not forget!!
allso can get much of a tuner so if that cam does to big you may have computer problems, you may need a reflash
Old Jan 6, 2009 | 03:52 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Before you go doing all that stuff, have you checked the cat, lower intake gasket,compression or leak down test? Have you done a full tune up ? Including all fluid and filter changes. Don't spend the money on the other stuff until you know everything else checks out,
Old Jan 6, 2009 | 06:25 PM
lastrights's Avatar
lastrights
+1 you could be surprised what a simple tune up will do, not only increase power but mpg also
