well heck
Old Jan 6, 2009 | 10:35 PM
Laramie1997's Avatar
Laramie1997
Originally Posted by JimkDaAdtman
I did find this recall is incomplete Don't know if it would have anything to do with it or not:
REPROGRAM PCM OBD CATALYST MONITOR
Looks like it's mainly for CA emissions though... So, shouldn't matter on mine..
And shouldn't cause it to throw this code..
I think that was in response to the cat problems that chrysler admitted to in 2005
I would be careful if you have it reflashed because I think that on the 2000 you will still get the death flash.
Old Jan 7, 2009 | 05:48 PM
JimkDaAdtman's Avatar
JimkDaAdtman
I aint gunna get it reflashed... I'll just let it go... I think I will wait to tear into it too much until after the tranny is fixed... I don't think it's anything too serious right now, it does seem to run ok, but the oil pump needs replaced, and I don't want o run it too much until that is fixed... Which will be done at the same time as the tranny.. Since it didn't happen till after the exhaust was fixed, I wonder if I knocked something loose, the after cat sensor wires are just hanging loose, and I did get caught on them, and pulled them kinda hard, might of caused a problem there maybe? I dunno..
Old Jan 7, 2009 | 06:28 PM
Laramie1997
hmm could be
Old Jan 7, 2009 | 06:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If you think the oil pump or shaft is bad then why are you starting it to begin with?
