More power
Old Jan 8, 2009 | 09:47 PM
Ram_2500_v8's Avatar
Ram_2500_v8
Default More power
Sorry im new at this i have a 5.9 v8 2500 and im trying to find out things i can do to the motor to give me more power without putting a chip in it. if you know of anything to do i would appriciate it if you would give me suggetions and cheap things would be better
Old Jan 8, 2009 | 09:50 PM
SmokeGrinder's Avatar
SmokeGrinder
yep chips suck, programmers are where its at...MP programmer, FIPK no more for air cleaner(see the DIY)....headers, exhaust, throttle body, 1.7RR...yaddy yaddy yah
Old Jan 8, 2009 | 10:00 PM
Ram_2500_v8
what size exhuast should i put on it for the most power
Old Jan 8, 2009 | 10:09 PM
SmokeGrinder
exhaust wont really give you more power because think of your engine as an air compressor, theres alot of variables affecting the air going in....also dont forget your exhaust is only as free flowing as your least free flowing part, it will give you quicker revs and slightly adjust the torque curve of your motor, but it gives you a nice sound haha.....if your going with headers go with shorties, hedman or edelbrock...the rest of the exhaust change over to 2.5" all the way if you do fake/true duel setup...if you do single exhaust do a 3" but im not a fan of it on gas engines....flowmaster mufflers run rampant original 40s or super 44s....if your elderly magnaflow...
Old Jan 8, 2009 | 10:14 PM
Ram_2500_v8
o ok thanks i have 2.5 duels but on stock headers
Old Jan 9, 2009 | 07:31 AM
lastrights's Avatar
lastrights
exhaust,52mm fastman,1.7 harland sharps , and the superchips flashpaq , highly recomend flashpaq, exspecailly if you got death flash, and our trucks our very detuned from the factory
Old Jan 9, 2009 | 10:59 AM
Ram2K1's Avatar
Ram2K1
There was a thread on here a few days back that had a good write-up link about 5.9's. It seems one of the best things to do to these engines for more power is new heads. That's a lot of work, but it's a must if you really want good power numbers. I can't remember what thread that link was in, but it was a good read. Other than that, my suggestions would be 1.7's, a new tb, and headers...followed by a good tune (SCT, maybe) to pull it all together.
Old Jan 9, 2009 | 11:10 AM
steve05ram360's Avatar
steve05ram360
define power... low end? top end? it matters...
to get the most low end keep your exhaust to a combined ~3" diameter area of flow, duals should be ~2.25". for a 5.9 motor get a 52mm fastman TB. I am a fan of the K&N FIPK and experimented with different filter sizes... stock sizing is ok but if you want more top end with the exhaust set at ~3", there is a K&N 6(or 7)x9 round filter that will give you more on top. It did not sacrafice too much on the low end.
If you search the archives for my setup... prior to 2006, you should be able to find what I had on there. I was able to get upper 13's, lower 14's for mileage on the hiway and had plenty of power in the mountains (sierra nevada's)
Old Jan 9, 2009 | 11:15 AM
Ram2K1's Avatar
Ram2K1
Yeah, but your truck's just a beast anyway.
Old Jan 9, 2009 | 11:29 AM
steve05ram360
the diesel is w/o a doubt... hp/tq on demand at the push of a button.
have a look @ this (its installed for over a year now...)
http://www.tstproducts.com/powermaxcrwithr49.aspx
