Ticking sound at 2500 RPM
#42
I had forgotten, my 96 did that. It was at lower RPM though. Idle and just above.
#45
I had what i thought was a vavle tick at around the same rpms, but since I had the water pump and T-Stat replaced the tick is gone (it was a short drive from the shop, I will be able to confirm tomorrow). What I have noticed that the temp gauge shows its running cooler. I had a total system flush as well, before when the truck was warmed up the temp needle was almost past the "2", now it doesn't even touch the "2". So, maybe mine was slowly over heating causing a valve to tick? The shop also said that it was a 195* Stat, I made sure of that.
I was watching my needle and it gets right on top of the "2". I may try a flush too!
#46
I started disconnecting the spark plug wires one at a time and when I got down to the #5 wire the rattle went away. Is there anything else besides a rod bearing this could be? Like I said before, I dropped the oil pan and there was no metal shavings in the pan, and when I tried moving the rods, the rods were tight. I didn't use any plastic gauge to check them, I just grabbed ahold of the caps and tried movng them. With the stethoscope I put the probe on the heat shield beneath the area under the #5 plug and you could hear the rattle (from 1800-2500 rpms) pretty plainly. Underneath the truck I put the probe on the shallow (front) end of the oil pan and you could hear it there as well, but not as plainly. I realize this can be a little decieving due to the way sound travels. As you may can tell, I am really hoping this is not the bearings!!
#47
#48
So a bearing always makes noise at idle also? When the truck is idleing it is pretty quiet other than the ticking of the injectors. You can't really hear this until around 1800 rpm and its the loudest at 2300-2500 rpm. And only after its at least halfway warmed up.
I cut the oil filter open and it looked clean. The only metal I seen came from where I sawed it in half. I pulled the pleats back and they were clean.
Thanks for giving me hope!!
#50
