Ticking sound at 2500 RPM
Old 03-08-2009, 09:33 AM
06RamTRX4's Avatar
06RamTRX4
06RamTRX4 is offline
Originally Posted by 98DodgeRam1500
Since I had some more time behind the wheel yesterday. it does not make the same tick as it did before, now I can barely hear a tick at 2500-2800.
I used to be 98DodgeRam1500, I got rid of the tick on my 98. I told it, but now i got a new tick. The Hemi tick. Can't escape these tickers.
  #72
Old 03-08-2009, 11:42 AM
TMS Bill's Avatar
TMS Bill
TMS Bill is offline
That sounds like a spun bearing ... get a mechanic's stethoscope and isolate the noise ... bet it's about halfway back on the block.
  #73
Old 03-09-2009, 09:54 AM
trucklover's Avatar
trucklover
trucklover is offline
I may be tearing this engine down shortly to track this problem down. When I find out what it is, I will post.
  #74
Old 03-09-2009, 06:55 PM
Ram2K1's Avatar
Ram2K1
Ram2K1 is offline
Good deal...better you than me
  #75
Old 04-07-2009, 09:04 AM
trucklover's Avatar
trucklover
We finally tore the engine down last night. Nearly all the rod bearings were severely worn right down to the brass. This engine only has 67,000 miles on it! I was using the Mobile 1 Synthetic oil. None had spun though. I will need to get the crank turned, and I am just going to go thru the entire engine also. I will be putting new heads (EQ heads with 2.02 valves) new cam and lifters (KRC 210x) and also the SCT tune from Hemifever. I am planning on cutting the runners on the intake to compliment the cam and heads.
  #76
Old 04-07-2009, 09:16 AM
dodgeram07's Avatar
dodgeram07
dodgeram07 is offline
damn dude, with only 67000 miles thats crazy, good luck with the build it sounds like a fun one (KRC 210x) that will sound nice
  #77
Old 04-07-2009, 10:37 AM
trucklover's Avatar
trucklover
Thanks, I am getting excited about it! It will take about a month to get everything back together, but as soon as I do I will try to post a video.
  #78
Old 05-20-2009, 12:15 AM
jmhai's Avatar
jmhai
jmhai is offline
Did this ever get figured out. I have noticed this same thing for the last year on my truck. Cruising the hwyway and at about 2500 rpms ticking, 200 rpms higher or lower nothing. Would like to know if this is just normal for some trucks. I don't think I can go thru everything the OP did. Did the overhaul stop it..?
  #79
Old 05-20-2009, 11:12 AM
trucklover's Avatar
trucklover
Still rebuilding!! The machine shop is very slow!!
This will take care of it though. Nearly all the bearings were down to the copper (connecting rod bearings). None had spun though, but I was very close.
  #80
Old 11-20-2009, 08:13 AM
01ram15005.9l's Avatar
01ram15005.9l
01ram15005.9l is offline
im having the same noise problem on my 01 1500 5.9 2wd...its coming from the left side of my steerin wheel like i can hear it threw a vent or somthing....and i cant hear it slightly with the hood open but like him it only around 2500 rpm gets louder when about to shift also. but i also have an exhaust leak right after my cat so idk...iv been told a blown head gasket? but i see no smoke or anything...i got sea foam to run through it today but idk.
Quick Reply: Ticking sound at 2500 RPM
