Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
- Dodge Ram: How to Check Tire Pressure
Step by step instructions for the do-it-yourself repairs
Check Your Tire Pressure
#24
Yeah, the press. on the sidewall is for maximum load capacity. Its all relative to what ply the tires are= if you have an 8 ply tire that calls for 80 psi max. on a 1500 then you'd more than likely to run 40-50 psi in them or whatever rides the best for you. Also if you run a larger size than stock you'll need to adjust the pressure to your needs. A good test is to run through the water and drive over some dry pavement and check the tread pattern to see how it contacts it.
