Transmission bands
Old Jan 13, 2009 | 01:05 PM
dblj16380's Avatar
dblj16380
Thanks for clearing that up MonteC. I figured you would know.
Old Jan 13, 2009 | 06:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You can buy the E Type socket set at any parts store, one of them will fit the front adjuster, if you can find a set that has sizes 11 and 13 , I think the 11 will fit the reverse adjuster. I don't know if they make those 2 sizes though. But I will be looking into it before I do it next time.
Actually if you are in a jamb, what I did with the reverse one, was use an open end 5/16 and put it on the adjuster half way on to the end of the screw, then used a 5/16 allen socket on the torque wrench and slid it in to the half of the open end that was sticking over the screw.
Old Jan 13, 2009 | 06:40 PM
MonteC's Avatar
MonteC
The reverse torx bits work also like zman said. (E-sockets)
Old Jan 13, 2009 | 06:49 PM
zman17's Avatar
zman17
I just did a search and there is an 11,but could not find a 13. But I'm 99 percent sure the 11 will do the trick for the reverse band. Probably just easier to stop a snap on or matco truck when you see one.
Old Jan 14, 2009 | 08:30 AM
MAGICDSSMAN's Avatar
MAGICDSSMAN
I have a rather large set of crows feet I could use to get on it I was just worried about the torque change with a crows foot and an adapter. I don't wanna under tighten or over tighten the bands.
Old Jan 14, 2009 | 09:14 AM
dblj16380's Avatar
dblj16380
I believe if you use a crow foot that it will alter the torque. If you search this forum for how to adjust the bands it tells you the torque to use (72 in/lbs) and how many turns to back it off. It also goes on to tell you what torque to use if you are using a special tool that it lists. I don't know what the special tool is, but it is probably similar to a crow foot.
Old Jan 14, 2009 | 06:14 PM
zman17's Avatar
zman17
Exactly right, the FSM states if you have to use the special extension, you change the torque to 50. A crows foot is a lot shorter than the extension (special tool ) shown in the FSM, but it still changes the torque any time you add leverage.
Old Jan 18, 2009 | 04:47 PM
MAGICDSSMAN
Well I finaly found a socket to work. The socket to use is a e14 star or reverse torque socket I got a set from harbor freight. The fit is a little tight but it does fit.
Old Jan 18, 2009 | 05:43 PM
zman17's Avatar
zman17
On the front one right? I might have had the size mixed up , but no way a 14 will work on the reverse adjuster.
Old Jan 18, 2009 | 07:33 PM
MAGICDSSMAN
Yea it was on the front band. I haven't dropped the pan yet to do the rear band. The truck has actualy been parked since may of last year when the tranny first started acting up. Hopefuly I will have the time to drop the pan tomorrow before I have to work.
