Transmission bands
Old Jan 12, 2009 | 01:53 PM
MAGICDSSMAN's Avatar
MAGICDSSMAN
Default Transmission bands
Does anybody know what kind of socket will fit the square adjusting screw on the front band.
I can get on it with a 9mm open end wrench but not a socket and I can't set it to the specific torque with an open end.
Old Jan 12, 2009 | 02:10 PM
trucklover's Avatar
trucklover
I have read the 8 point 5/16" socket will work.
Old Jan 12, 2009 | 03:35 PM
MAGICDSSMAN
I appreciate the help I will have to try that tomorrow.
Old Jan 12, 2009 | 04:06 PM
dblj16380's Avatar
dblj16380
Another trick that I found out myself is that if you don't have the specific 4 or 8 point socket is that many garage mechanics like myself have 6pt and 12pt sockets. A 12 pt would fit also. I'm not 100% sure on the size though. I just rebuilt my 46RE trans and the Rear band inside the tranny pan is a 5/16 square nut and the outside one is a torques bit.
Old Jan 12, 2009 | 05:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It's called an E-type socket. Works on the front one,IIRC it was an E-12. My set had 10,12 And 14. No 11 or 13, so I had to make some thing up to do the reverse one. Trust me, NO 6 or 12 point will work, sae or metric.
Old Jan 12, 2009 | 07:57 PM
deeznutts's Avatar
deeznutts
http://dodgeram.org/tech/transmissio...T_band_adj.htm
hope that helps..
Old Jan 13, 2009 | 04:54 AM
zman17's Avatar
zman17
My Adjusters have no torx in them.
Old Jan 13, 2009 | 05:56 AM
dblj16380's Avatar
dblj16380
What type of trans do you have zman? I have the 46RE and the outside adjustment (I believe it to be the front band) has a torx head adjuster and a standard lock nut. The only reason I know this is because I just had my trans on the bench Saturday rebuilding it and I had to adjust it.
Old Jan 13, 2009 | 11:35 AM
MAGICDSSMAN
Mine is the same way. No torx for the front band on the outside of the tranny. Hopefully I will have time to get up to the shop tomorow and play with it a little.
Old Jan 13, 2009 | 12:26 PM
MonteC's Avatar
MonteC
Earlier model 46re's do not have a torx head screw. Its just a square nut, major PITA.
Most of the major tool companies make a socket for it, (snap on, matco, mac)
