Transmission bands
Old Apr 28, 2009 | 09:37 PM
  #21
KY2500's Avatar
KY2500
2000 RAM 46RE took a torx for the front band(outer) and the rear band took a 5/16 8pt AKA cheese head, double square. In a pinch, Sears hardware (not the same as the regular store) keeps them in stock. Here is the item number.
Craftsman 5/16 in. Easy-to-Read Socket, 8 pt. STD, 3/8 in. drive
Item# 00945791000 Model# 45791
Price $3.79
Old Apr 29, 2009 | 09:29 AM
  #22
dblj16380's Avatar
dblj16380
My rear band was a square bolt, not sure on the size, probably the 5/16. You can get an 8 pt socket for it or you could just use a 12 pt socket as well. As long as the # of pts is divisible by 4 then your good and it will have the right spacing from edge to edge.
Old Apr 29, 2009 | 01:01 PM
  #23
KY2500's Avatar
KY2500
A 12 point will not work! You would think that a 12 point would work because of the math involved but it doesn't. The reason is that the square bolt is really not square it has round corners. A 12pt relies on the corners to grab the bolt hence there is no corner so hence it doesn't work. Hopefully this will "put to bed" this faulty logic.
Old Apr 30, 2009 | 03:51 PM
  #24
dblj16380's Avatar
dblj16380
I understand your "logic", but I just rebuilt my trans and adjusted my bands using a 12 pt socket and it worked fine for me. There isn't really much force on the bolt to strip it out if it doesn't have a great grip. Its only 72 in/lbs. Maybe mine was different or something but it worked.
