upper ball joint?
Old Jan 15, 2009 | 12:26 AM
caggi's Avatar
caggi
Question upper ball joint?
what's the best way to remove a upper joint from a ram van. Do I need a socket? Or just a big adjustable wrench? If so, what size is that? thanks
Old Jan 15, 2009 | 05:37 AM
dblj16380's Avatar
dblj16380
If the vans are anything like the trucks then they are pressed in and the best way to get them out is to get a ball joint press. You can buy them or rent them from AutoZone, Murray's, etc. Just double check to see if your ball joint sits in a tapered hole, if it does, make sure to get the tapered press cups.
Old Jan 16, 2009 | 05:25 PM
caggi's Avatar
caggi
Default ball joint
thanks DB, looks like it screws in, it has flats on it like a nut. I'm thinking I need the big dodge socket, 2 & 9/64" but I'm not sure?
Old Jan 17, 2009 | 10:24 AM
dblj16380's Avatar
dblj16380
Well I've never worked on the vans so good luck with that. I hope it goes smoothly.
