Stupid K&N cleaning question...
Old Jan 16, 2009 | 07:21 PM
TIMIDONE's Avatar
TIMIDONE
Default Stupid K&N cleaning question...
Title says it all...I have 2 K&N filters which I have never cleaned...ya ya ya shush!
Anyway, so I am cleaning my truck one today following directions...it is drying now.
What my question is is that after cleaning it looks the same dark color, not the bright red when I bought it. Did I clean it right? Does it never go back to the original color? I just wanna know so I know I cleaned it right before applying the oil, thanks!
Old Jan 16, 2009 | 07:29 PM
aim4squirrels's Avatar
aim4squirrels
The oil you reapply is red, not the filter media.
it should be slightly white when clean, IIRC.
Old Jan 16, 2009 | 07:38 PM
TIMIDONE's Avatar
TIMIDONE
ah good to know, thanks...think I cleaned it well enough...I hope! time to let it dry.
Old Jan 16, 2009 | 07:52 PM
aim4squirrels
I think it was a uniform gray color when wet with the cleaner solvent and dried lighter. the spray on oil is red and you should apply very lightly when the filter is dry.
Old Jan 16, 2009 | 08:06 PM
TIMIDONE's Avatar
TIMIDONE
Ok thanks...spray on? I think mine is drip but it is downstairs and Im too lazy took look right now
Old Jan 17, 2009 | 01:37 AM
TIMIDONE's Avatar
TIMIDONE
Mine was spray on...inside is gray outside is gray/red now Hope I didn't spray to much on, I did 1 light coat moving it quickly waited 1 hr and another quick coat...no drips and wiped off an excessive I saw, plus it is on a towel right now until tomorrow when I put it back on.
Gonna redue the S-bolt thing...my last was too long and pain in the tail to take off and put on...back to home depot I go!
Old Jan 17, 2009 | 08:46 AM
aim4squirrels
if you have a hack saw you can cut the length of your S-bolt down and 99% of the time have no problems re-threading the nut.
Old Jan 17, 2009 | 09:09 AM
xskylinedx's Avatar
xskylinedx
Just make sure you don't over oil it, it can screw up sensors. All you really need to do
is get the filter media red.
Old Jan 17, 2009 | 11:37 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Whether you cut it down or make a new one, put the nuts on before you cut it. Then you can just take the nut off and that will clean the threads.
Old Jan 17, 2009 | 03:10 PM
TIMIDONE's Avatar
TIMIDONE
Yea I know the nut on before cutting trick...what is the length (when bent) of everyone's S-bolt?
Mine is 5" and I actually had to bend the dang thing to get the cover off. I am thinking the filter is 3" so maybe 4" at the max?
BTW where is the DIY for the Round Filter Install? I can't seem to find it! Did they remove it or am I just going blind? A link would help if someone finds it!
