Coil springs or coil spacers?
Old Jan 20, 2009 | 06:19 PM
  #61
dodgewilltravel's Avatar
dodgewilltravel
Originally Posted by meanwhitemopar
well i aswell will either be getting the 2500 or 3500 springs, i thnk the 2500 V10 springs should work fine, and some add-a-leafs shoul work just fine. and i know about the shocks and the track bars so i should have an ok lift once im done. and for less then 300 buck ya cant beat it.
and i am one person to go aginst those stabilizers. all they do is put a bad straign on your steering box. and the tie rods, and just about every other steering component. i outright took mine off because it is just nicer on the truck when there is none. not to mention unless you do comp style offroad, or rock crawling, you cant even feel the differance on or off road.
I had to fab my own stabilizer because they dont make them for 01 1500 2x4, when I put my 285x75x16 on, going over rr tracks, bridges, at a slite angle the wheel would whip out of my hands, after putting stabilizer on the wheel stopped doing all that stuff.
