may scrap this motor
Old Jan 18, 2009 | 12:08 PM
meanwhitemopar's Avatar
meanwhitemopar
Default may scrap this motor
ok i got the new crank in, i gave her a few turns (spark plugs out, rockers and lifters out so i dont mess anything up) and she turned over three full times, so i know everything is good and seated. and then i started torqueing everything down and turning it is now phyisicly impossible. i have a feeling the block has to be line drilled, and not to mention, the rings need to be redone and thats more work then its worth.
so everyone knows, i am torquing the connecting rods down to 45 flbs and the mains are at 85flbs like the alldata computer says.
so i ot some plastigage and i will be checking that stuff, and then i am going to probably take it out, put it back in the box, take it back to dvanced, and tell then my block is messsed up and get my money back and get a new, not used but new motor, they are $1800 with free shipping and it is complete, all you need is your oil pan, and timing chain cover, and all the stuf for the front of the motor (ac, alternator, waterpump ect...) and it comes with all the gaskets... not to mention it also comes with a 5 year unlimited mile warrentiy
Old Jan 18, 2009 | 12:53 PM
siberjon's Avatar
siberjon
WOW ok, i need some more info on this new motor for 1800!!!
If that is true I will order one next month for that price!!!!
Do you have links?
Old Jan 18, 2009 | 01:09 PM
meanwhitemopar
i will get you guys the link here in a little while. it is a great price i know. and i have to see if i can get them to ship it where i need it. cause i have never done this before... but yea, i will get ya the like cause they have motors for just about anything as far as i now. the motor i am looking at fits all vin code y vehicles. and they have the 360's so i dont know. but i will give more later, cause i have to find it again. it dint save in my favorites button....
Old Jan 18, 2009 | 01:14 PM
pcfixerpro's Avatar
pcfixerpro
Do you have links?
check ebay. There are some on there. Check out PROMAR engines (ebay or real website)
Old Jan 18, 2009 | 01:21 PM
CaptCameltoe's Avatar
CaptCameltoe
remember the 360 is balanced differently then the 318, so you'll need a 360 harmonic balancer, torque convertor and "maybe" the flexplate. The 5.2 pcm should be fine for a stock 360, but a 5.9 pcm is easy enough to find if your worried about it.
Old Jan 18, 2009 | 02:33 PM
dhvaughan's Avatar
dhvaughan
on the motor you're working on. i assume the heads are still on, and the pistons are still in the cylinders and pushed up out of the way as much as possible. so when you have the crank in and torqued, everything is ok, and crank turns freely.
so then you start attaching connecting rods and torque them, and it binds up.
i don't think the problem is the crank and the mains. i think one or more of your connecting rods is binding on the rod journal.
try attaching and torquing them one at a time, to see which one creates the bind.
after that's identified - i'm not sure where to go next, but it sounds like either a rod journal is oversize, or the bearing is over.
have you got, or can your get hold of a micrometer to measure the journals.
Old Jan 18, 2009 | 08:08 PM
sungod's Avatar
sungod
Please don't return the crank after you have installed it. That is not fair to the next poor sap that gets your returned parts. There is no telling what harm you may have done to it.
Old Jan 18, 2009 | 09:38 PM
meanwhitemopar
well it is not the crank thats bad. and not to be rude. i will return any part i dont need. not to mention, i havent done anything to it. i still have the motor completely torn apart
and i have all the connecting rods attached, and with the mains lossened, i can turn it, its tough cause of the compresion but i can turn it. once i torque one of them, i can still turn it. i torqued the next one. still turn it, torque that third one, and is done. i can put a really big impact gun (3/4 inch) to the bolt where the harmonic blancer goes, at the end of the crank, and it wont budge. lossen that one, it turns again. and i tried to torque a differant one. same thing. so its just easier...
and i might put a 360 in it, havent decided yet. i know about the harmonic balancer, and the internal and external balance. my only question is, whta kind of headers can i run with a 360 to bolt to my exaughst, so i dont have to modify that much. cause i know the manafolds are differant by like 1/4 inch on the 360's.
i dont know yet because my local autozone can get me the reman motor, same setup as the one i found for 1800, just a three year warrentie for 1644. so i think i my do that to get it faster and less for shipping
Old Jan 19, 2009 | 12:52 PM
dodge15004x45.9's Avatar
dodge15004x45.9
look at this
http://philadelphia.craigslist.org/pts/998694217.html
Old Jan 19, 2009 | 01:23 PM
meanwhitemopar
hey that may help. hang on and i am going to try to email him. i wounder if he will ship. i mean i have no way of getting it if not. but that would be nice cause my reverse doesnt work either, just bolt this one up... that would be awesome
