Need your help, 1.7 install fail
Old 01-25-2009, 03:11 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
The Harland Sharps are easy to install. Providing nothing outside of the valve covers got messed up.
  #22
Old 01-25-2009, 03:19 PM
Vader's Avatar
Vader
Vader is offline
Originally Posted by zman17
Do you mean re-torqued?
Correct sir!
  #23
Old 01-25-2009, 03:46 PM
zman17's Avatar
zman17
zman17 is offline
Check the small ground wire at the power steering pump bracket.The one that runs along the driver side valve cover.
  #24
Old 01-25-2009, 06:22 PM
Vader's Avatar
Vader
Vader is offline
Thanks, will do.
  #25
Old 01-25-2009, 09:27 PM
JohnnysArt's Avatar
JohnnysArt
JohnnysArt is offline
I re-torqued mine after 100 miles just to be safe.
johnny.
  #26
Old 01-25-2009, 09:33 PM
Vader's Avatar
Vader
Vader is offline
johnny.
Good idea, if it didn't take a day to remove the valve covers.
  #27
Old 01-25-2009, 09:36 PM
JohnnysArt's Avatar
JohnnysArt
yes I know it--it is a pita for sure--but it's better to be safe.
Hows it running now?
johnny
  #28
Old 01-25-2009, 09:50 PM
Vader's Avatar
Vader
Vader is offline
Better, I cleared the codes and have to see if they return.
  #29
Old 01-25-2009, 09:52 PM
JohnnysArt's Avatar
JohnnysArt
let us know how you like the performance --once you drive it more and hopefully no more problems.
johnny.
  #30
Old 01-25-2009, 09:54 PM
talon6's Avatar
talon6
talon6 is offline
when i changed mine. i left the valve covers off and cranked the motor till oil started coming out on all of them,then a re-torqued them all.then reassembled.killed two birds with one stone. re-torque and no dry start up.
Quick Reply: Need your help, 1.7 install fail
