Need to install tranny parts
Old Jan 26, 2009 | 06:08 PM
lv360ram's Avatar
lv360ram
Default Need to install tranny parts
I ordered several parts today to make my tranny better.
manual valve - "This valve allows converter charge in park and reverse and
DOES NOT cause forward clutch drag in park. No machining required."
switch valve - "This valve prevents lock up shudder, soft torque converter apply
and torque converter overheating."
press reg valve - "This valve is designed to allow oil to flow into the converter
charge circuit as soon as the engine is started."
These parts need to be installed in the side of the valve body. I'm wondering if I will be lucky enough that the VB is lower than the tranny case so I can replace these parts without pulling the VB out.
Will I get lucky?
Old Jan 26, 2009 | 06:13 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I'm sure montec will chime in here, and I'm sure you mean VB not TB? Because it would be alot of work to install all that stuff in the side of the throttle body, And did you buy a kit like a TransGo or did you get the parts individually? Just curious.
PurplDodge's Avatar
PurplDodge
What?
Old Jan 26, 2009 | 06:18 PM
lv360ram's Avatar
lv360ram
Doh!
yes, "valve body" -Thanks zman
I edited the post. Sorry I was sober when I wrote the post.
I bought the individual parts.
Old Jan 26, 2009 | 06:20 PM
zman17's Avatar
zman17
He edited his post from TB to VB before my reply.
Old Jan 26, 2009 | 07:15 PM
MonteC's Avatar
MonteC
You have to pull the valvebody out of the transmission.
Did you get the parts from Sonnax?
Old Jan 26, 2009 | 08:11 PM
lv360ram's Avatar
lv360ram
Darn! but thanks for the confirmation.
Yea, the parts are Sonnax.
Old Jan 27, 2009 | 12:13 PM
dblj16380's Avatar
dblj16380
The valve body really isn't that hard to get out from the trans.
1)Disconnect all linkage to the transmission itself (There is a part coming out of the trans and has two brackets attached to it)
2)Disconnect the wiring harness right next to it.
3)Drop the pan and remove the filter
4)Unbolt the valve body (I think about 8 11mm and 2 T25 torx screws)
5)GENTLY wiggle the valve body down to get the linkage post and wiring harness through the trans body.
6)Once loose, disconnect the parking rod by detaching the c-clip holding it on
7)Remove valve body!
Old Jan 27, 2009 | 12:16 PM
MonteC's Avatar
MonteC
Thats good stuff there. Those are three valves i think are a must for any 46rh/re.
Old Jan 27, 2009 | 06:16 PM
hometheaterman's Avatar
hometheaterman
I tried to remove the valve body on my old transmission after having everyone tell me how easy it is. I read directions and asked lots of questions I even looked at lots of pictures and never did get it out. I finally had it towed to a shop. I think that may have just been one of the only times I've ever attempted a project and it been as hard or harder than I thought. Usually I have no problem doing stuff. Even stuff I haven't done before but that was just a pita. I could get it loose but never get it to drop down.
