Cranks, no start.
Old Jan 29, 2009 | 03:15 PM
DerfW3's Avatar
DerfW3
Question Cranks, no start.
My ol' lady's truck just died. ('99 1500 4x4, 5.2 w/ 197k on it) It was running crappy (she put "Dry Gas" in the tank just before the engine started cutting out), did a tune up; replaced ignition from the coil to the plugs. Ran good for a week then died again. Starter spins good, has spark, has gas in the tank, no engine codes. "Check Gages" lights up during cranking. Fuel relay is good.
Any suggestions? Is there a fuse before the relay?
I'm just hoping I don't have to drop the tank in a foot of snow.
Old Jan 29, 2009 | 03:22 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Get a fuel pressure tester. 49lbs is around where it should be. If that checks out maybe crank position sensor or cam position sensor.
Old Feb 6, 2009 | 03:10 PM
DerfW3's Avatar
DerfW3
Default Well Crap
Turns out it's the pump gone bad. What kind of timing is that?!
Old Feb 6, 2009 | 03:47 PM
zman17's Avatar
zman17
Does anything ever happen at a good time? BTW, where in NE are you ? Any where close to Manchester, NH
Old Feb 6, 2009 | 04:37 PM
DerfW3's Avatar
DerfW3
Timing definitely sucks. I have to fix it while it's still frozen outside or else tomorrow I'll be laying in the mud!
I'm closer to Manchester CT! About 2 1/2 hours away.
You wouldn't know where I can get a cheap air intake for the truck? The stock one exploded when it backfired through the snorkel!
Old Feb 6, 2009 | 05:40 PM
zman17's Avatar
zman17
Do the 14x3 conversion, or take a ride to the local JY.
Old Feb 6, 2009 | 07:36 PM
DerfW3's Avatar
DerfW3
Not too hip on current mods so you'll have to 'splain a 14x3 conversion.
Old Feb 7, 2009 | 06:26 AM
zman17's Avatar
zman17
Here is the 14x3 air filter mod. https://dodgeforum.com/forum/2nd-gen...er-update.html
