Oil Pan Removal help
Old Apr 29, 2019 | 09:38 PM
Brian Redding's Avatar
Brian Redding
[QUOTE=HeyYou;3437498]Lots of threads regarding that...... and even more recent than this four year old thread.[/QUOTE new to the site not use to it dont know how to look for newer post
Old Apr 29, 2019 | 09:46 PM
Actually, I have found that most website search engines suck. Better to use Google, and tell it specifically which site you want to search.
I don't *think* you need to lift the motor to pull the pan though. (I know you don't have to on the 4x4 trucks, done it several times......) Basically, disconnect the battery, pull the starter, the engine mount to trans braces, (if they are till there) and the trans dust shield. Then its just 12 million oil pan bolts. (not really, but, it sure seems that way when you are laying on your back to do it......) Oh, and don't forget to drain the oil first. (and remove the filter.....)
Old Apr 29, 2019 | 09:54 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I can sit under mine and do it also my Durango didn't have the motor to trans braces and I would eat flex plates like no tomorrow
