Bigger Oil filter for the 360/318 -Cheap-
Old Feb 3, 2009 | 10:35 PM
PurplDodge's Avatar
PurplDodge
I think if you added one of those (oil coolers) with your large filter, you would be hitting the frame with the filter. IMHO I think its not really needed unless you were racing in the desert or something like that.
Old Feb 3, 2009 | 10:41 PM
madmax0r's Avatar
madmax0r
Ya,
Im not real fond of connecting an oil cooler in that way anyhow.. I wouldn't buy one
Old Feb 3, 2009 | 11:23 PM
JohnnyRebs360's Avatar
JohnnyRebs360
Fram HP1
Brand:FramProduct Line:Fram HP Series Oil FiltersPart Type:Oil FiltersPart Number:FRM-HP1Oil Filter Style:CanisterHeight (in):5.750 in.Outside Diameter (in):3.719 in.Filter Bypass Relief Valve:YesRelief Valve Open (psi):22 psiAnti-Drainback Valve:YesSmallest Particle Filtered:18 micronsMaximum Burst Pressure (psi):500 psiThread Size:3/4-16 in.Gasket Outside Diameter (in):2.813 in.Gasket Inside Diameter (in):2.422 in.Gasket Thickness (in):0.328 in.
www.SummitRacing.com
Old Feb 3, 2009 | 11:38 PM
Laramie1997's Avatar
Laramie1997
whats the matter with fram filters? I have been using them for over 50,000 miles and have never had a problem...
Old Feb 3, 2009 | 11:59 PM
PurplDodge's Avatar
PurplDodge
They are not as good quality as K&N, WIX, Mobil 1, etc...
http://minimopar.knizefamily.net/oil....html#champion
Old Feb 4, 2009 | 12:33 AM
Laramie1997
eh, I read it and it seems that the only real major drawback is the cardboard end cap material. I havent had a problem with them. Should I ever have a problem with them I will change back to wix. I used to run those all the time, but I had one split on a 1995 Chevy 1500.
EDIT: I use the tough guard type so that may be the difference.
Old Feb 4, 2009 | 12:34 AM
BlueBeast2's Avatar
BlueBeast2
People on the Mustang site I belong too always say they are made of cardboard and fall apart. I used to always use them. I since have started using the Mopar one on my truck. Its right around the same price at wal mart
Old Feb 4, 2009 | 12:38 AM
PurplDodge's Avatar
PurplDodge
I used to use the Mopar one for a while, too. I stopped and went back to K&N because I missed the ease of installing and taking off the filter. That little nut is the best idea yet. I wish a cheaper filter(like a Fram or a WIX filter) had that.
Old Feb 4, 2009 | 12:43 AM
BlueBeast2's Avatar
BlueBeast2
99% of the time i change them by hand. I dont need a little nut. I got big ones
Old Feb 4, 2009 | 01:40 AM
madmax0r's Avatar
madmax0r
The nut is a good idea, but everyone already has oil filter wrenches, so its whatever for me
